Floating muscle via points and combined Motion
Dear AnyBody Team
I have two questions for you:
  1. Is there a way to model muscle via points that are not fixed on a
    segment but will change their position according to the position of a
    joint? For example a muscle wraps only over the Viapoint1 if the joint
    is flexed more than let’s say 90 degrees, or the viapoint moves
    up/down with changing extension/flexion…
  2. I would like to define the angles of joint B (Universal) according
    to the position of joint A (Revolute). Let’s assume some arbitrary
    relation between these to joints:
B1 = 2A and
B2= 0.5A + 5/180
pi
Therefore I have defined the following driver:
AnyKinEqSimpleDriver CombinedMotion = {
AnyKinMeasureLinComb Measure = {
AnyRevoluteJoint &J1= Main.Model.Jnts.JointA;
AnyUniversalJoint &J2= Main.Model.Jnts.JointB;
     Coef = {{2, -1, 0},{0.5,0,-1}};
     Const = {0, 5/180*pi};
   DriverPos = {0,0};
   DriverVel={0,0};
   Reaction.Type={Off, Off};
As far as I understand the AnyKinMeasureLinComb function, I can only
define linear relations between various measures. Is there a way to
incorporate a non-linear relation between these two measures? E.g. B1=
A^2 or using a logarithmic scale?
Many thanks for your help.
Christine
Hi Christine
Here are some answers
Q1: the short answer is that this is not possible. In order to do such a
thing you will need to introduce an extra segment which the muscle would go
through, and drive it separately to obtain this.
Q2: you are right; the combination measure can only be used for creating
linear relations. You can make use of the norm combination measure to select
between different LinComb measures like yours. Then these measures could
each have different coefficients. I think it would be possible, but it is
not easy to work with I known, but this is the only option at the moment.
Of christine_schaerer
Sent: 16 May 2008 10:35
Subject: [AnyScript] Floating muscle via points and combined Motion
Dear AnyBody Team
B1 = 2A and
B2= 0.5A + 5/180
pi
DriverPos = {0,0};
DriverVel={0,0};
Christine
Hi Søren
I have feared I would get this answer, although I hoped there would be
an easier way to implement floating via points. But thanks for your
help anyway.
Theoretically, I could run an analysis to determine the position of
the joint A in order to calculate the position of joint B. However, I
still hope there is another solution to it…
Do you see any possibility to incorporate a lookup table?
Within our group, we had some discussions if (and how) it is possible
to include look up tables. For example, I could create an
AnyFunInterpol Lookuptable = {
with the respective input and output values given by T and Data
respectively. But now I am stuck, how can I convert this lookup table
into a driver?
However I do it, I always got the error message:
‘DriverVel’ : Expression evaluation failed at moment ‘DesignVar’ :
‘AAngle’ : argument will not be ready for evaluation until moment ‘PosVar’
Any Idea?
Many thanks
Christine
> Hi Christine
would go
to select
it is
moment.
> Best regards
> Søren
> _____
On Behalf
> Dear AnyBody Team
> B1 = 2A and
> B2= 0.5A + 5/180
pi
> DriverPos = {0,0};
> DriverVel={0,0};
> Christine
Hi Christine,
You got this error message because of the order of evaluation in
time. You cannot change this order, but to avoid the problem one
solution is to write this lookup table in a text file.
You should run two analyses for that. In the first one, drive the
first joint alone and set the second one to some constant value. Then
copy in a text file the position of the first join regarding to time.
In the second analysis keep driving the first joint and use an
AnyKinEqInterPolDriver using the text file for the second one. You
might have to read the text file first through an AnyFunInterpol to
then be able to extract separately T and Data and input that in the
AnyKinEqInterPolDriver. Now you can apply any operation you want
(linear or non linear) to the Data member of the
AnyKinEqInterPolDriver, and so on driving the position of the second
joint depending on the position of the first joint.
I hope this is clear.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “christine_schaerer”
<christine_schaerer@…> wrote:
> Hi Søren
be
> help anyway.
I
possible
table
> into a driver?
moment ‘PosVar’
> Any Idea?
> Many thanks
> Christine
wrote:
> > Hi Christine
such a
> would go
creating
> to select
measures could
but
> it is
> moment.
> > Best regards
> > Søren
> > _____
> On Behalf
Motion
> > Dear AnyBody Team
on a
of a
joint
according
> > B1 = 2A and
> > B2= 0.5A + 5/180
pi
> > DriverPos = {0,0};
> > DriverVel={0,0};
only
to
E.g. B1=
> > Christine
