I posted a question last night but for some reason it is not there when I checked now.
I am using full body gait and having some problems with the force plate type code in AuntoDetection when I try to run the model.
I keep getting this error : ‘(’ unexpected
Model loading skipped.
Even though I used the recommended auto detection force plate code in the anyscript wiki, I still get the same error even if I changed the force plate type.
Please find attached the model I am using (Gait full body). I made the following changes in it:
1- In the Model Setup I changed some of the marker configuration (commented some of them out)
2- In Trial specific data I changed:
-Name file (deadlift) C3D file
Gravity forces
Rotated the mannequin to (-90,0, 90)
Force plate vertical direction “Z”
Added plate 4
Eliminated Cal Matrix
After the following changes I tried to load the model and it gave me an unexpected error where the whole program crashes. The previous error that I had was in regards to the force plate type as I mentioned, but now its a new error.
Thank you for all your help. I just have one more inquiry, I noticed that you have changed the weights of some markers making some higher than other, is there any specific reason behind your selection?
Just for me to know because I will be working with other different moves ( ex. squat) so it would help if you could explain to me or maybe if you can refer me to some sources that would.
