Hello!
Now I have uploaded the model. The model was located in
Repository5.beta/ARep/Lund/…
From the start the folder was called StandingModel but I changed the name to
ElbowFlexion Model when I zipped it. Though I don’t think it makes any
difference.
I’m working with to different input data. One with loads in the hands and one
without.
//FileName = “filtElbowFlex.txt”; // with 4 kg loads in the hands
FileName = “filtNoW.txt”;// no loads
The one with loads works kinematically even when adding the driver of the GH
joint with the input data:
//FileName = “filtElbowFlexHumerus9mod.txt”;
The one without loads is the one that I sent figures of. Now I made a little
change in the Mannequin file, because I found there the following line:
AnyFolder Load = {
AnyVec3 TopVertebra = {0.000, 0.000, 0.000};
AnyFolder Right = {
AnyVec3 Shoulder = {0.000, 0.000, 0.000};
AnyVec3 Elbow = {0.000, 0.000, 0.000};
AnyVec3 Hand = {0.000, 0.000, 150.000}; ???
So I wander why is there a load in the hand but no loads anywhere else. I
changed it to 0 load in the hand. But then the Dynamic Analysis didn’t give the
same result as before and a few seconds before the end it stopped.
Well, if you have time to look at it, please do. I thÃnk I need also some help
to add the weight to the hands as you recommended. I’m not sure in what file I
should make the changes.
Also I must say that the RMS data that I showed you might be wrong in time a
hole second. So from the matlab figure I sent you cannot compare it to the
AnyBody Result.
Best Regards,
Signe
AnyBody Support <support@anybodytech.com> wrote:
Hi Signe
I have taken a look at the graphs and the explanation, it looks at
bit strange that the acitivity from the model is out of phase with
the inclination. One reason could be acceleration forces, have you
checked the values of the segments in the arms? You may find them
in the model tree under segments as rDDot.
The activity from a model can be compared with EMG although the
height of the curves can not be compared directly. There is also a
phase shift because the muscles EMG will occur slightly before they
develop the force and activity.
If you continue to have problems please zip your model and upload it
and we will have a look at it.
Søren AnyBoy Support
— In anyscript@yahoogroups.com, Signe Jeppesen <signejeppesen@…>
wrote:
> Hello John
> I have uploaded the files in the file section as you told me.
But now I will send one more figure:
> I have put together the result from inclinometer measurements,
EMG measurements and AnyBody studies in a matlab figure.
> Measurement of the inclination of the forearm has been used as a
driver in AnyBody by using a frame in the wrist relative the global
reference frame as a measure. I have taken the position of the FE
joint to compare the AnyBody result with the input data. The
inclination results has been devided with pi, and the RMS results
with the maximal measured activity during this measure, to be able
to put all results in the same figure.
> Have a look!
> There might be some displacement in time between the
inclinometer measurements and the EMG measurements.
> Best Regards
> Signe
> AnyBody Support <support@…> wrote:
> Hello Signe,
> The moment arm of the biceps becomes very small when the elbow is
> extended, so for some load conditions you can get large biceps
> forces for this situation.
> Attached files get stripped off when you send a message to the
> group. To send files, please log into the group’s file section and
> upload the file and we would be happy to take a look at it.
> Best regards,
> John
> — In anyscript@yahoogroups.com, Signe Jeppesen <signejeppesen@>
> wrote:
> > Hello!
> > I have made study of Elbow Flexion movement. I get a result that
> > seems funny to me. When the arm is straight down along the body
> (start
> > position) the force Fm of the Biceps breve muscle is the
highest.
> When the
> > arm is flexed the most (you can feel the muscle is working when
> keeping
> > that position) the muscle force Fm is the lowest. It is logical
to
> me
> > that the muscle should act the oposite way. The result can be
seen
> in
> > the attached zipped files which are Bitmapes figures. One is Fm
of
> > Biseps_brachii_caput_breve, the other is position of the FE
joint.
> > Best Regards
> > Signe
> > Yahoo! Mail
> > Use Photomail to share photos without annoying attachments.
> AnyBody Technology provides free support on the use of the AnyBody
Modeling System and the Scripting language AnyScript. Other users
are welcome to join the discussions.
> SPONSORED LINKS
> Biomedical engineering degree Biomedical engineering
career Biomedical engineering program Biomedical engineering
schools Biomedical engineering jobs Biomedical engineering
> YAHOO! GROUPS LINKS
> Visit your group “anyscript” on the web.
> To unsubscribe from this group, send an email to:
> anyscript-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> Yahoo! Mail
AnyBody Technology provides free support on the use of the AnyBody Modeling
System and the Scripting language AnyScript. Other users are welcome to join the
discussions.
SPONSORED LINKS
Biomedical engineering degree Biomedical engineering career
Biomedical engineering program Biomedical engineering schools Biomedical
YAHOO! GROUPS LINKS
Visit your group "anyscript" on the web.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Relax. Yahoo! Mail virus scanning helps detect nasty viruses!
