Full instep push with AnyBody
thank you for your offer, to help if there are any problems.
I have a problem with the Inverse Dynamic at the full instep push.
This is my source text:
// Todo: Write a small description of your model here
Main = {
// The actual body model goes in this folder
AnyFolder BeinModel = {
// Global Reference  Frame
  AnyDrawRefFrame  DrwGlobalRef = {
   ScaleXYZ = {0.1, 0.1, 0.1};
   RGB =  {0,1,0};
  AnyRefNode Huefte = {
    sRel =  {0,0,0};
  AnyRefNode BeugerNode = {
      sRel  = {0,-0.03,0};
};  // Global reference frame
//  Segments
AnyFolder Segs = {
  AnySeg Oberschenkel = {
    r0  = {0, 0, -0.15};
    Mass = 3;
    Jii = {0.01, 0.01,  0.001};
    AnyDrawSeg drw = {};
    AnyRefNode  HuefteNode = {
      sRel = {0,0,0.13};
    AnyRefNode  KnieNode = {
      sRel = {0,0,-0.135};
    AnyRefNode  HKreuzbandNode = {
      sRel = {0,-0.03,-0.1};
    AnyRefNode  VKreuzbandNode = {
       sRel = {0,0.03,-0.1};
    AnyRefNode  Quadriceps = {
      sRel = {0,0.04,0.1};
    AnyRefNode  Wadenmuskel = {
      sRel = {0,-0.035,-0.135};
};  //Oberschenkel
  AnySeg Unterschenkel = {
    r0  = {0, 0, -0.50};
    Mass = 4;
      sRel  = {0,0,0.13};
    AnyRefNode KnoechelNode =  {
      sRel = {0,0,-0.13};
      sRel = {0,-0.03,0.1};
      sRel = {0,0.03,0.1};
      sRel = {0,-0.05,0.1};
    AnyRefNode  Achilles = {
      sRel = {0,-0.02,-0.1};
    AnyRefNode  Sehne = {
      sRel = {0,0.02,-0.1};
      sRel = {0,0.025,0.13};
  }; //Unterschenkel
   AnySeg  Fuss = {
    r0 = {0,0.05,-0.715};
    Mass = 2;
    Jii  = {0.001, 0.0002, 0.001};
  AnyDrawSeg DrwSeg = {};
      sRel = {0,-0.05,0.025};
      sRel = {0,-0.06,-0.005};
      sRel = {0,-0.015,0.02};
      sRel = {0,-0.065,-0.005};
    AnyRefNode  FusNode = {
      sRel = {0,0.045,0.05};
      ARel =  RotMat(90*pi/180, y);
    AnyDrawSTL DrwSTL = {
        FileName  = "ballaballa.stl";
        ScaleXYZ = {0.01, 0.01, 0.01};
        RGB  = {0.2,0.4,0.5};
  };  //Fuss
}; // Segments
AnyFolder Jnts = {
  AnyRevoluteJoint  Huefte= {
    Axis = x;
    AnyRefNode &GroundNode =  ..GlobalRef.Huefte;
    AnyRefNode &OberschenkelNode =  ..Segs.Oberschenkel.HuefteNode;
  }; // Huefte joint
  AnyRevoluteJoint  Knie = {
    Axis = x;
    AnyRefNode  &OberschenkelNode = Main.BeinModel.Segs.Oberschenkel.KnieNode;
    AnyRefNode  &UnterschenkelNode = Main.BeinModel.Segs.Unterschenkel.KnieNode;
  };  // Knie joint
  AnyRevoluteJoint Knoechel = {
    Axis  = x;
    AnyRefNode &UnterschenkelNode =  Main.BeinModel.Segs.Unterschenkel.KnoechelNode;
    AnyRefNode  &FussNode = Main.BeinModel.Segs.Fuss.KnoechelNode;
  }; //  Knoechel joint
}; // Jnts folder
AnyFolder  Drivers = {
  AnyKinEqSimpleDriver  HuefteMotion = {
    AnyRevoluteJoint &Jnt = ..Jnts.Huefte;
    DriverPos  = {-45*pi/180};
    DriverVel = {75*pi/180};
    Reaction.Type  = {Off};
  }; // Huefte driver
      AnyKinEqSimpleDriver  KnieMotion = {
      AnyRevoluteJoint &Jnt = ..Jnts.Knie;
      DriverPos  = {-90*pi/180};
      DriverVel = {80*pi/180};
    }; // Knie driver
      AnyKinEqSimpleDriver  KnoechelMotion = {
      AnyRevoluteJoint &Jnt =  ..Jnts.Knoechel;
      DriverVel  = {25*pi/180};
    }; //  Knoechel driver
  }; // Driver folder
  AnyFolder  Muscles = {
    // Simple muscle model with constant strength =  300 Newton
    AnyMuscleModel MusMdl = {
      F0 = 250;
    AnyViaPointMuscle  HKreuzband = {   // Name
      AnyMuscleModel &MusMdl =  ..Muscles.MusMdl; //verweis auf die F0=250
      AnyRefNode  &Org = ..Segs.Oberschenkel.VKreuzbandNode; //Ursprung
      AnyRefNode  &Ins = ..Segs.Unterschenkel.HKreuzbandNode; //Angriff
      AnyDrawMuscle  DrwMus = {
     MaxStress = 1000000;  //definiert den  Querschnitt der Muskeln
   };//Hinteres Kreuzband
   AnyViaPointMuscle  VKreuzband = {
      AnyRefNode &Org =  ..Segs.Oberschenkel.HKreuzbandNode;
      AnyRefNode &Ins =  ..Segs.Unterschenkel.VKreuzbandNode;
   };//Vorderes Kreuzband
     AnyViaPointMuscle  Beuger = {
     AnyRefNode  &Org = ..GlobalRef.BeugerNode;
     AnyRefNode &Ins =  ..Segs.Unterschenkel.BeugerNode;
     AnyDrawMuscle DrwMus = {};
   };//Beuger  (Flexor)
    AnyViaPointMuscle  Quadriceps = {
      AnyRefNode &Org =  ..Segs.Oberschenkel.Quadriceps;
      AnyRefNode &Ins =  ..Segs.Unterschenkel.Quadriceps;
   };//Quadriceps
    AnyViaPointMuscle  Achilles = {
      AnyRefNode &Org =  ..Segs.Unterschenkel.Achilles;
      AnyRefNode &Ins =  ..Segs.Fuss.Achilles;
   };//Achillessehne
    AnyViaPointMuscle  Sehne = {
      AnyRefNode  &Org = ..Segs.Unterschenkel.Sehne;
      AnyRefNode &Ins  = ..Segs.Fuss.Sehne;
};//vordere sehne
    AnyViaPointMuscle  Wadenmuskulatur = {
      AnyRefNode &Org =  ..Segs.Oberschenkel.Wadenmuskel;
      AnyRefNode &Ins =  ..Segs.Fuss.Wadenmuskel;
   };//Wadenmuskulatur
 };  // Muscles folder
  AnyFolder Loads = {
  AnyForce3D  ballaballa = {
    AnyRefNode &FusNode =  ..Segs.Fuss.FusNode;
    F = {0,-40.4,0}; // Force in Newton
}; // Loads folder
}; // BeinModel
// The study: Operations to be performed on the model
AnyBodyStudy BeinModelStudy = {
AnyFolder &Model = .BeinModel;
// RecruitmentSolver = MinMaxSimplex;
// tStart = 0;
// tEnd = 1;
// nStep = 100;
Gravity = {0.0, -9.81, 0.0};
}; // Main
I would be very thankfull, if you can help me, to make the inverse dynamics run.
Best Regards,
seak88
Hi Christoph,
the hip flexion is not carried. Move the Quadriceps origin to the Globalref.
Sebastian
Hi Sebastian, thank you fore your Support…at wednesday evening my brain was working because of the problem and at once i get the solution of the probleme and i move the Quadriceps to the Global Ref…
exactly, what you say and it works:-)
Best regards…christoph
