to investigate the role of unweighting in reaction ground forces in
gait model,can we change some parameters and setting in model so that
the new forces can be achived?suppose a BWS(Body weighty suppoet)
system is implemented which is a harness that affects in pelvis?I/m
looking forward to your response.
I am not sure I understand it right, but you are doing gait analysis
on a subject that has been hooked up with a harness so you kan relief
the subject for some weight?
Do you know how much weight the harness carries?
I guess you can apply a AnyForce or a AnyForce3D to the pelvis in the
pulling direction.
I hope that was an answer to your question, else please write again.
Christian, AnyBody Support
> Jalal.Arabneydi
> MSc student
> Best regards.
I realised that what I wrote in the last post would not work. I don’t
think I understand your question. Did the subject walk over force
plates and was supported by the harness?
Could you explain in greater detail?
> Hi Jalal
> pulling direction.
> Best regards
> > Jalal.Arabneydi
> > MSc student
> > Best regards.
