Hi John
It is great to hear that the model is working now, i am sorry that
your last posting was not ansewered, but you seem to have solved the
problems now
Please let me know if you have more questions.
Thanks for the kind words.
Søren, AnyBody support
— In anyscript@yahoogroups.com, “johnzengwu” <jwu@…> wrote:
> Hi Soeren:
> I have found out that there are some problems with my motion data.
The
> horizontal force is too large compared to the vertical force.
> Comparing our data with your sample Gait3D, I found: the ratio of
the
> peak force magnitude of the horzontal (x-axis) to vertical (z-
axis) in
> Gait3D sample is 1:6, while it is about 1:2 in our gait motion
data.
> By scaling of the horizontal force to a factor of 0.33, I obtained
the
> forces in soleus and gastrocnemius comparable to those obtained in
> Gait3D-sample. My gait model seems fine. I will check the
calibration
> of the force plate in our lab next week.
> I really appreciate your great suggestions and efforts.
> John Wu
> — In anyscript@yahoogroups.com, “johnzengwu” <jwu@> wrote:
> > Hi Soeren:
> > After a revising of the JointAndDrivers.any, my model works OK.
The
> > kinematics look well.
> > The muscle force in gastrocnemius of the left leg is still too
large.
> > However, the muscle forces in the right leg seem OK. All my four
sets
> > of data result in similar muscle force outputs. Can you test my
model
> > using your new kinemtics optimizer, to see if it’s possible to
improve
> > the results. If my model is proven to be correct, I will just
use the
> > force output of the right legs. Since the left leg starts first
in our
> > tests, it is resonable to believe that that the movement is not
yet
> > “stablized” at start.
> > I have up-loaded my model as “Gait3D_rev4.zip”.
> > Regards,
> > John
> > > Hi Soeren:
> > > Finally I got my model working. It’s now a “clean” solution,
without
> > > using AnkleEversion driver, just driving via motion markers.
It seems
> > > the JointAndDrivers.any in Gait3D does not work on my data. I
have
> > > revised the driver at three driving ponts, and it works well
now. The
> > > gait seems normal. I am still working on it to test my another
data
> > > sets. I have four sets of gait data collected from four
different
> > > subjects. I will let you know the results and what I did.
> > > Thanks for your help,
> > > John
> > > — In anyscript@yahoogroups.com, “AnyBody Support” <support@>
wrote:
> > > > Hi John
> > > > The kinematic optimizer is working on a model which has a
fixed
> > > > topology, so i can not specify a specific dof like the
eversion of
> > > > the ankle to be rigid unfortunately.
> > > > You are writing that you have the joint angles measured in
Peak
> > > > system, maybee it would be possible for you to drive the
model
> using
> > > > these angles directly?. This requires that you know exactly
how
> > > > these angles are measured and then create new rotational
> measures in
> > > > AnyBody reflecting this. If these two models match
kinematically
> > > > joint angle drivers should be a good solution.
> > > > Best regards
> > > > Søren
> > > > > Hi Søren:
> > > > > I believe the best way to solve the problem is the
kinematics
> > > > > optimization. The model should be stable, if you can solve
the
> > > > > over-constrained kinemtics using your new optimizer.
> > > > > If the problem is related to the ankle eversion/inversion,
I
> have a
> > > > > better solution. I can drive the ankle eversion directly,
while
> > > > still
> > > > > driving the model using all other motion markers. We have
data
> for
> > > > all
> > > > > joint angles measured using Peak system. Could you try it
using
> > > > your
> > > > > kinematics optimizer? If it does not work, please try to
put ankle
> > > > > eversion to zero. I have up-loaded the ankle-eversion data
and the
> > > > > revised JointAndDrivers.any. (Gait3D_ankle_eversion.zip)
> > > > > The unsymmetric model seems too complicated. And I am not
sure if
> > > > my
> > > > > model will work, putting so much effects to change the
human
> model
> > > > to
> > > > > unsymmetric. So, I would not proceed in that direction.
> > > > > Thanks for your effects,
> > > > > John
<support@>
> > > > wrote:
> > > > > > Hi John
> > > > > > I have tried to optimize the kinematics using an
optimizer made
> > > > by
> > > > > > Michael Skipper Andersen, who is working on a Ph.D.
project,
> > > > about
> > > > > > kinematic analysis of over-determinate systems.
Unfortunately I
> > > > have
> > > > > > not been doing successful doing so yet. The reason is
the feet;
> > > > > > since there are only two markers here it creates
problems for
> > > > the
> > > > > > algorithm to determine primarily the eversion/inversion
dof, in
> > > > a
> > > > > > good way. Especially the left foot is problematic
because the
> > > > heel,
> > > > > > mallous and metatarsal markers are almost lying on
straight
> > > > line.
> > > > > > This problem will persist regardless of which method we
use to
> > > > > > impose the movement on the model. If you a have a
dataset with
> > > > more
> > > > > > markers on the forefoot it would be easier for the
algorithm to
> > > > > > solve this problem.
> > > > > > You are right that improving the kinematics manually is
rather
> > > > > > difficult and time consuming; this was why I tried using
> > > > Michael’s
> > > > > > optimizer on your problem. If it had been successful the
output
> > > > > > would have been the optimized marker positions, segments
> > > > lengths,
> > > > > > and joint angles, but I am afraid that for the current
data set
> > > > this
> > > > > > is not possible, I had to abandon this strategy after
having
> > > > spend
> > > > > > quite some time to make it work.
> > > > > > It is possible that scaling the left and right side
differently
> > > > will
> > > > > > improve this model. This can not be done straight away
and
> > > > requires
> > > > > > some changes to be made in the BRep.
> > > > > > I will try list the needed changes here:
> > > > > > 1. In the AnyMan you need to make a left and right side
folder
> > > > > > obviously, containing the segment lengths for the two
sides.
> > > > > > 2. In the UniformScaling file you need to create a left
and
> > > > right
> > > > > > side scaling for the legs segments.
> > > > > > 3. In the BodyModels directory in the specific BodyModel
file
> > > > you
> > > > > > are using you need to introduce a new folder reference,
for
> > > > example
> > > > > > named ScalingRightLeft, in the Right and Left side
folders.
> This
> > > > > > reference should point at the scaling laws just created.
This
> > > > folder
> > > > > > reference should have the same name in both folders, but
point
> > > > at
> > > > > > different scalinglaws.
> > > > > > 4. In the Leg3d/Seg…any file you need to point at the
scaling
> > > > law
> > > > > > defined in the bodymodel right and left folder., instead
of the
> > > > > > existing scaling which are there today.
> > > > > > This should introduce different scaling to the right and
left
> > > > side.
> > > > > > I hope scaling the left and right side differently will
help
> > > > solve
> > > > > > the problem, but the inversion and eversion of the foot
will
> > > > > > continue to be a problem.
> > > > > > Best regards
> > > > > > Søren, AnyBody Support
wrote:
> > > > > > > Hi Søren:
> > > > > > > I have improved the model a little bit. It can now run
to the
> > > > end.
> > > > > > > But, the kinematics is still a problem. The updated
model is
> > > > > > > Gait3D_rev3, which is up-loaded.
> > > > > > > John
wrote:
> > > > > > > > Hi Søren:
> > > > > > > > Thanks for your time and efforts. I agree with you
that the
> > > > > > problem is
> > > > > > > > likely caused by the kinematics. But, it is a tough
job. I
> > > > have
> > > > > > spent
> > > > > > > > a lot of time to have my model scaled and motion
markers
> > > > > > adjusted.
> > > > > > > > When it is initialized, the model looks very good.
But, it
> > > > runs
> > > > > > only
> > > > > > > > 20 steps and stops. What I found is that the subject
in our
> > > > > > study is
> > > > > > > > unsymmetric. It is shown in my model, if you look at
it
> > > > closely.
> > > > > > The
> > > > > > > > thigh and shank lengths are different from left to
> right. We
> > > > also
> > > > > > > > found it in our direct physical measurements. This
may
> cause
> > > > the
> > > > > > > > problem. My questions is: how to adjust the left and
right
> > > > thigh
> > > > > > and
> > > > > > > > shank length separately?
> > > > > > > > I have revised the MotionMarkerDrivers, but it does
not
> help.
> > > > > > > > I have up-loaded my up-dated model “Gait3D-rev3”. All
> motion
> > > > > > markers,
> > > > > > > > which are not used to drive the model, have been
removed in
> > > > the
> > > > > > model
> > > > > > > > to make it clearere to view.
> > > > > > > > Thanks,
> > > > > > > > John
> > > > <support@>
> > > > > > wrote:
> > > > > > > > > Hi John
> > > > > > > > > I have looked a bit more into the model
> > > > > > > > > I think the main problem could be the kinemtatics.
I
> > > > tried
> > > > > > again to
> > > > > > > > > insert a reaction force on the right and left
ankle
> > > > > > > > > inversion/eversion and the activity dropped from
15 to
> > > > 5.8.
> > > > > > This
> > > > > > > > > might be cause by the angle between the foot and
the floor
> > > > > > (tilt), it
> > > > > > > > > looks like he is walking on the lateral side of the
> feets.
> > > > > > > > > Secondly i looked at the motion of the pelvis, if
you
> look
> > > > the
> > > > > > > > > motion from the front there are some very large
rotations
> > > > of
> > > > > > the
> > > > > > > > > pelvis, and it can be seen that there is a large
error on
> > > > the
> > > > > > Asis
> > > > > > > > > markers. Therefore i tried adding reaction forces
to the
> > > > hip
> > > > > > > > > abduction and external rotatation together with
the ankle
> > > > > > inversion
> > > > > > > > > moment.
> > > > > > > > > AnyReacForce LeftSideJoints ={
> > > > > > > > > AnyKinMeasureOrg &ref2=
> > > > > > > > > Main.Model.HumanModel.Interface.Left.AnkleEversion;
> > > > > > > > > AnyKinMeasureOrg &ref5=
> > > > > > > > > Main.Model.HumanModel.Interface.Left.HipAbduction;
> > > > > > > > > AnyKinMeasureOrg &ref6=
Main.Model.HumanModel.Interface.Left.HipExternalRotation;
> > > > > > > > > AnyReacForce RightSideJoints ={
Main.Model.HumanModel.Interface.Right.AnkleEversion;
> > > > > > > > > Main.Model.HumanModel.Interface.Right.HipAbduction;
Main.Model.HumanModel.Interface.Right.HipExternalRotation;
> > > > > > > > > This helped the activity to drop to 1.4. I think
the
> > > > > > explanation is
> > > > > > > > > that the momentarms around the hip joint becomes
too
> small
> > > > for
> > > > > > this
> > > > > > > > > amount of pelvis “tilt”.
> > > > > > > > > So i think the next step will be to adjust the
motion.
> > > > > > > > > I looked at the moment curves and compared them to
the
> > > > curves
> > > > > > which
> > > > > > > > > can be found in book "Dynamics of human gait "
> > > > > > > > > http://www.kiboho.co.za/GaitCD/GaitBook.pdf
> > > > > > > > > On page 42 there is a curve for the moment around
the
> hip,
> > > > > > knee and
> > > > > > > > > ankle, when i compare the knee moment with the
> > > > > > > > > curve “Main.Study.Out_kinetics.M_Knee_Flex” it
looks
> quite
> > > > > > different?
> > > > > > > > > My impression is that it is the kinematics which
are
> > > > causing
> > > > > > these
> > > > > > > > > problems primarily. I think the scaling and the
marker
> > > > > > postions
> > > > > > > > > should be adjusted until the motion gives a
smaller
> > > > hip “tilt”
> > > > > > and
> > > > > > > > > the foot tilt are more horizontal and aligned with
the
> > > > floor.
> > > > > > > > > Best regards
<jwu@>
> > > > wrote:
> > > > > > > > > > Hi Søren:
> > > > > > > > > > Thanks for your suggestions. I have improved my
model,
> > > > as
> > > > > > > > > suggested.
> > > > > > > > > > 1. The CenterOfPressure drivers have been
revised. Now,
> > > > I
> > > > > > drive
> > > > > > > > > > CenterOfPressure only in x-y plane, and raise it
to a
> > > > height
> > > > > > > > > of “pz”,
> > > > > > > > > > which can ben adjusted. By doing this, the
muscle force
> > > > in
> > > > > > > > > > gastrocnemius is reduced by 10%, still too high.
> (See my
> > > > > > revised
> > > > > > > > > > “enviroment.any” file.)
> > > > > > > > > > 2. All section masses have been scaled. But this
has
> > > > little
> > > > > > > > > influence.
> > > > > > > > > > (see revised “man.any”)
> > > > > > > > > > 3. I have checked the joint moment by
using “No_Muscle”
> > > > and
> > > > > > output
> > > > > > > > > the
> > > > > > > > > > joint muscle force. The sum of plus and minus
force
> > > > gives
> > > > > > the
> > > > > > > > > moment.
> > > > > > > > > > I have added a data processing unit
> > > > (“Output_kinetic.any”)
> > > > > > to
> > > > > > > > > output
> > > > > > > > > > the joint moment. Note: M and nM respresent
moment and
> > > > > > normalized
> > > > > > > > > > moment, respectively. When normalized to the
body mass,
> > > > the
> > > > > > joint
> > > > > > > > > > moments are consistent with published data.
> > > > > > > > > > 4. I found that the soleus muscle seems not
active and
> > > > has
> > > > > > no force
> > > > > > > > > > output. All external forces are balanced by the
> > > > > > gastrocnemius
> > > > > > > > > muscles.
> > > > > > > > > > I have checked by varying the force magnitude in
> > > > > > environment.any.
> > > > > > > > > > Using “F=kforce(t)" with varied “k”, I am able
to
> > > > change
> > > > > > the
> > > > > > > > > ground
> > > > > > > > > > reaction force input. The output of the forces
of
> > > > > > gastrocnemius are
> > > > > > > > > > almost proportional to those in force plate.
> > > > > > > > > > 5. In “JointsAndDrivers.any”, I have tested to
> switch on
> > > > > > > > > Reaction.Type
> > > > > > > > > > at HeelYLDrv and HeelYLDrv to
> Reaction.Type={Off,On,On},
> > > > the
> > > > > > soleus
> > > > > > > > > > forces then appear and gastrocnemius force
decrease by
> > > > 1/3.
> > > > > > It
> > > > > > > > > seems
> > > > > > > > > > the problem is at ankle joints.
> > > > > > > > > > I appreciate it you can take time to look at my
revised
> > > > > > model, and
> > > > > > > > > > give me some further suggestions.
> > > > > > > > > > The revised model “Gait3D-rev2” has been up-
loaded.
> > > > > > > > > > John
Support”
> > > > > > <support@>
> > > > > > > > > wrote:
> > > > > > > > > > > Hi John
> > > > > > > > > > > I have tested your model and found a few things
> > > > > > > > > > > 1: the position of the CentrOfPressure segment
> seem to
> > > > be
> > > > > > too
> > > > > > > > > low.
> > > > > > > > > > > This can be corrected by adding a new node in
the
> > > > > > globalref
> > > > > > > > > which is
> > > > > > > > > > > located higher, and then refering to this node
in the
> > > > > > measures
> > > > > > > > > used
> > > > > > > > > > > for driving this segment.
> > > > > > > > > > > 2: The ankle eversion/inversion seems a bit
strange,
> > > > this
> > > > > > might
> > > > > > > > > > > cause problems for the muscles carrying this
dof. In
> > > > order
> > > > > > to
> > > > > > > > > see if
> > > > > > > > > > > this is a problem, i inserted these lines in
the
> > > > > > > > > > > JointsAndDrivers.any file
> > > > > > > > > > > AnyReacForce AnkleEversion ={ //stc added
these
> > > > > > reactions
> > > > > > > > > because
> > > > > > > > > > > AnyKinMeasureOrg
> > > > &ref1=Main.Model.HumanModel.Interface.Right.AnkleEversion;
> > > > > > > > > > > AnyKinMeasureOrg
> > > > &ref2=Main.Model.HumanModel.Interface.Left.AnkleEversion;
> > > > > > > > > > > The lines adds a reaction force to ankle
> > > > > > inversion/eversion
> > > > > > > > > dofs. It
> > > > > > > > > > > help the activity to drop a bit, but not
enough.
> > > > > > > > > > > 3: Then i switched off the muscles and looked
at the
> > > > > > moments.
> > > > > > > > > The
> > > > > > > > > > > left knee moment looks a bit strange you can
see by
> > > > > > looking at
> > > > > > > > > the
> > > > > > > > > > > property
> "Main.Study.Output.Model.HumanModel.Left.Leg.JointMuscles.KneeJnt.d
> > > > > > > > > of
> > > > > > > > > > > 0.Muscle..Ft”
> > > > > > > > > > > it will give you two curves one of them is the
> > > > negative
> > > > > > moment
> > > > > > > > > the
> > > > > > > > > > > other one the positive moment. Normally the
negative
> > > > one
> > > > > > should
> > > > > > > > > be
> > > > > > > > > > > dominant in these models and it should not
change
> sign
> > > > > > during
> > > > > > > > > the
> > > > > > > > > > > stance phase as it does in this case, so i
think this
> > > > is
> > > > > > worth
> > > > > > > > > > > investigating a bit. I have not been able to
find the
> > > > > > cause of
> > > > > > > > > it,
> > > > > > > > > > > typical reasons could be kinematics of the
left leg,
> > > > the
> > > > > > way the
> > > > > > > > > > > force is applied etc.
> > > > > > > > > > > 4: The last thing i have noticed is about the
> scaling,
> > > > in
> > > > > > the
> > > > > > > > > > > AnyMan.any file it seems that your subject
have a
> > > > weigth
> > > > > > of 78
> > > > > > > > > kg,
> > > > > > > > > > > but looking at the segment masses of the thigh
and
> > > > shank
> > > > > > they
> > > > > > > > > are
> > > > > > > > > > > unchanged compared to the original Gait3D
model. I
> > > > think
> > > > > > these
> > > > > > > > > > > values should be slight higher.
> > > > > > > > > > > I hope it helps you move on, although it do
not solve
> > > > the
> > > > > > entire
> > > > > > > > > > > problem.
> > > > > > > > > > > Best regards
<jwu@>
> > > > > > wrote:
> > > > > > > > > > > > Hi Søren:
> > > > > > > > > > > > I am applying Gait3D using my own data. The
model
> > > > seems
> > > > > > > > > working and
> > > > > > > > > > > > the magnitude of the joint moments are also
OK. But
> > > > the
> > > > > > > > > predicted
> > > > > > > > > > > > magnitude of muscle forces are very strange.
> > > > Especially,
> > > > > > the
> > > > > > > > > force
> > > > > > > > > > > in
> > > > > > > > > > > > gastrocnemius reaches over 4500 N, it’s too
large;
> > > > wile
> > > > > > force
> > > > > > > > > in
> > > > > > > > > > > > soleus is only 200-300N, too small. I have
checked
> > > > your
> > > > > > sample
> > > > > > > > > > > Gait3D,
> > > > > > > > > > > > the muscle forces are OK. I have run several
other
> > > > data
> > > > > > sets,
> > > > > > > > > and
> > > > > > > > > > > the
> > > > > > > > > > > > results are similar. It seems there is a
systematic
> > > > > > problem in
> > > > > > > > > my
> > > > > > > > > > > > model, but I cannot find it. Can you look at
my
> > > > model
> > > > > > and give
> > > > > > > > > me
> > > > > > > > > > > some
> > > > > > > > > > > > idea where the problem may be?
> > > > > > > > > > > > I have up-loaded my model: “Gait3D-revised”
> > > > > > > > > > > > Thanks,
> > > > > > > > > > > > John Wu
