Hello all,
I’m using the GaitFullBody model and removed the lower limbs and the left arm as I’m only interested in movements with the right arm.
I’m using 3D motion capture data to drive my model and I seem to have a problem with driving the Elbow correctly. The RELB marker seems to twist the Elbow incorrectly and not according to the original .c3d file even though I’ve turned off filtering in AnyBody.
So in short:
The RELB marker is showing movement which is not coherent with the original .c3d data. I’ve turned off filtering in AnyBody. The RELB position read in AnyBody (through AnyChart) does not show any difference with the original .c3d data, yet the movement is not the same.
I can not add the model just yet, as it exceeds the upload limit.
Does anyone have had a similar problem and/or solution?
Greetings,
Hans Essers
