Hi, i’m trying to import c3d data from the upper extremities to the GaitFullBody model. After adjusting the ModelSetup file to the Marker System we used i get following Problems:
Problem while performing Optimization process:
- Optimization (Operation: Main.Studies.ParameterIdentification.Optimization):
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : PelvisWidth : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : ThighLengths : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : ShankLengths : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : FootLengths : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : TrunkHeight : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : UpperArmLength : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/ModelSetup1.any : LowerArmLength : Design variable bounds must be specified : This design variable is missing proper bounds
ERROR(OBJ.DES4) : C:/D…s/S…a/A…a/A…y/A…x/A…1/A…n/E…s/G…1/GaitFullBody.main.any : ParameterIdentification.Optimization : Design variable bounds must be specified : This operation requires design variable bounds to be specified
Setting bounds in OptimizeAnthropometricsOnOff.any:
#class_template OptimizeAnthropometricsOnOff (PelvisWidthOnOff,ThighLengthOnOff,ShankLengthOnOff,FootLengthOnOff,HeadHeightOnOff,TrunkHeightOnOff ,UpperArmLengthOnOff,LowerArmLengthOnOff ,Model1, Model2 ){
#if Model1 == 1
AnyFolder &ref= Main.Studies.ParameterIdentification ;
ref={
AnyFolder &Lengths=Main.Studies.KinematicStudyForParamterIdentification.HumanModel.Scaling.AnthroSegmentLengths;
#if PelvisWidthOnOff=="On"
AnyDesVar PelvisWidth = {
Val = .Lengths.PelvisWidth;
Min = -50; //Standard -1+e300 for Lower Bound of design space
Max = 50; //Standard 1+300 for Upper Bound of design space
#endif[/i]
etc.
After setting bounds the system is shutting down after the KinematicAnalysis:
Loading Settings Script from : 'C:\Documents and Settings\Sascha\Local Settings\Application Data\AnyBody Technology\AnyBody.4.x.x\Settings.anyst
Settings loaded
Loading Main : “C:\Documents and Settings\Sascha\Application Data\AnyBody Technology\AnyBody.4.x.x\AMMRV1.1\Application\Examples\GaitFullBody_1\GaitFullBodymain.any”
Scanning…
Parsing…
Constructing model tree…
Linking identifiers…
Evaluating constants…
Configuring model…
Evaluating model…
Loaded successfully.
Elapsed Time : 32.063000
- Running macro file : C:\Documents and Settings\Sascha\Application Data\AnyBody Technology\AnyBody.4.x.x\AMMRV1.1\Application\Examples\GaitFullBody_1\Sequence1.anymcr (Operation: Main.RunMotionAndParameterOptimizationSequence):
Macro command > operation Main.Studies.ParameterIdentification.ParameterOptimization
Macro command > run
1.0.0) Operation Sequence: (Operation: Main.Studies.ParameterIdentification.Analysis):
1.0.0.0) Kinematics (Operation: Main.Studies.KinematicStudyForParamterIdentification.Kinematics):
1.0.0.0.0) PreOperation (Operation: Main.Studies.KinematicStudyForParamterIdentification.Kinematics.PreOperation):
1.0.0.0.0) InitialConditions (Operation: Main.Studies.KinematicStudyForParamterIdentification.InitialConditions):
1.0.0.0.0) …Design variables have been updated.
1.0.0.0.1) …Load time positions have been re-established.
1.0.0.0.2) …Kinematic analysis completed. The kinematic constraints have been resolved.
1.0.0.0.3) …Initial conditions are fully updated.
1.0.0.0) Kinematic analysis…
1.0.0.98) …Kinematic analysis completed
What is the reason for shutting down the software?
