GaitLowerBody with only legs and pelvis
Is it possible to delete everything but the legs and the pelvis?
When you open the GaitLowerExtremity example in the repository,
you can see that some muscles are connected between thigh and lumbar lumbar spine segments.
Main.Studies.HumanModel.BodyModel.Trunk.MusclesSpineLeft.PsoasMajor
Main.Studies.HumanModel.BodyModel.Trunk.MusclesSpineRight.PsoasMajor
So if you want to delete all segments except the legs and the pelvis,
then you should delete these muscles first.
But because these muscles are also related to the generation of hip joint moments, if you delete these muscles, then the other muscles should work more.
Then the situation of muscle overloading may happen.
It’s up to your decision.
I hope this may help you.
Thanks for the answer Moonki!
