Hello:
I was trying the GaitLowerExtremity model in Lesson 5, Making Things Move. I am using Anybody 6.0.
Unfortunately I cannot find GaitLowerExtremity folder under AMMR.v1.6; therefore I copied that folder from AMMR.v1.5 to v1.6.
The model looks right after loading (F7). Then I located MotionAndParameterOptimizationSequence as instructed by the tutorial and clicked the “Run”. An error message "Constrain no. #0 in ‘Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.PatellaMovement’ above error tolerance 0.000001, and the kinematic analysis failed in time step 0
I am surprised to find that the file provided in tutorial has this problem. Did I use the wrong file? If so can anyone send me the correct folder (works for Anybody 6.0)?
Thanks a lot!
Phoebe
