GaitLowerExtremity
I’m trying to load a c3d file into the GaitLowerExtremity model. The model loads but will not get through the optimization sequence without error. I have added drivers for pelvisthorax, lateralbend, neck, and ankle eversion into the main file within the KinematicStudyForParameterIdentification folder. I’m still receiving an error that the kinematic analysis failed. Where should I go from here?
Thanks
please upload the whole Application folder zipped.
Sebastian
Since my previous post, I downloaded version 4.2 and am having a different problem getting the model to load. All I have is a c3d file. I’m not sure how to get the euler output files or if they are needed.
[SIZE=1]ERROR(OBJ.FILE1)[/SIZE] : [SIZE=1]C:/U…s/s…2/D…p/A…s/A…2/A…n/M…s/G…y/JointsAndDriversOptimized.any[/SIZE] : [SIZE=1]JntDriverTrunk.FileName[/SIZE] : Problem with file : C:\Users\sanford22\Desktop\AnyBody4.2Models\AMMRV1.2\Application\MyModels\GaitLowerExtremity\Jaredwalk0005-output-euler-trunk.txt : The data file does not exist.
Thanks!
The euler output files are generated automaticaly by the optimization sequence. So if you run succesfuly the optimization the text files should be there and ready to use for the inverse dynamic analysis.
Best regards, Sylvain.
