I’m trying to build a model of an 8 yr old during a gait cycle. As the gait
between this age and adult gait is not too different, I’m adapting the
GaitUniMiami model using scaling methods to adjust the model anthropometrics.
I’ve have changed the scaling of the skeletal segments based upon a define body
weight and height, through altering the AnyMan.any file so the
AnthroSegmentLengths file is parameterised (so it is similar to that of the
scaling tutorial). Although the model rescales, the feet of the skeleton not
longer contact the force plate. The inverse dynamics still work and compute
muscle forces. Therefore, I wondered if the model should contact the ground, or
if this is just graphical and the muscle forces can be presumed accurate.
Many thanks
Pete
Hello Pete,
If you just scale the model it will not deliver the right results. What is
your approach for the ground reaction forces?
Sebastian
Of dc_pete
Sent: 16. marts 2009 14:22
Subject: [AnyScript] GaitUniMiami
anthropometrics.
body weight and height, through altering the AnyMan.any file so the
or if this is just graphical and the muscle forces can be presumed accurate.
Many thanks
Pete
Hi Pete !!
It good your idea to scale the model, but you must scale with the same ratio the
mannequin,the folder which contain all sensors. You try to look if you can
change the value in folder Environment and JointAndDrivers.
Once you do that, you can simulate and compare the result.
Â
Simon
— En date de : Mar 17.3.09, AnyScript Support <anyscriptsup@anybodytech…com>
a écrit :
De: AnyScript Support <anyscriptsup@anybodytech.com>
Objet: RE: [AnyScript] GaitUniMiami
À: anyscript@yahoogroups.com
Date: Mardi 17 Mars 2009, 15h23
Hello Pete,
Sebastian
From: anyscript@yahoogrou ps.com [mailto:anyscript@yahoogrou ps.com] On Behalf
Of dc_pete
anthropometrics.
AnthroSegmentLength s file is parameterised (so it is similar to that of the
or if this is just graphical and the muscle forces can be presumed accurate…
Many thanks
Pete
Hi Sebastian
Thanks for your reply (and simon). I don’t quite understand how to scale the
model correctly so apologies for all the questions.
Unfortunately, at the moment I don’t have any ground reaction forces for the
age I’m modelling at the moment. So - is it possible to alter the model so the
existing ground reaction forces are reduced to a reasonable percentage of the
applied scaled body weight during the gait cycle. Or do I need reaction forces
for the age I am trying to model for the inverse to work?
For later reference when we plan to obtain juvenile gait data â€" do the c3d
files have to obtained in a specific marker set up (I’m trying to use a 6
D.O.F. set up but it does integrate with the model)
Many thanks
Pete
— On Tue, 17/3/09, AnyScript Support <anyscriptsup@anybodytech.com> wrote:
From: AnyScript Support <anyscriptsup@anybodytech.com>
Subject: RE: [AnyScript] GaitUniMiami
Date: Tuesday, 17 March, 2009, 2:23 PM
Hello Pete,
Sebastian
Of dc_pete
anthropometrics.
Many thanks
Pete
Hi Pete,
In my opinion it’s not the best solution to simply scale the ground reaction
forces. It will be difficult to get good results out of this. You could
model the ground contact with reaction forces, which jump in with
conditional contact when the foot hits the ground. Please have a look at the
tutorial about this. But in this case you have to model also the upper body
in a proper way to get the right forces. So, obviously the best solution is
to get a consistent dataset for motion and force data from an experiment.
You can basically use any Marker set you like. Basically, the more markers,
the better. Especially on the foot there should be enough markers, at least
3.
Sebastian
Of Pete Watson
Sent: 18. marts 2009 18:28
Hi Sebastian
the existing ground reaction forces are reduced to a reasonable percentage
of the applied scaled body weight during the gait cycle. Or do I need
reaction forces for the age I am trying to model for the inverse to work?
For later reference when we plan to obtain juvenile gait data - do the c3d
Many thanks
Pete
Hello Pete,
Sebastian
Behalf
Of dc_pete
anthropometrics.
Many thanks
Pete
