Does each blue line in the above figure represent the plantar pressure at various positions of the plantar? If so, how do I read the specific stress data?If I use a force plate, can I obtain the pressure data of multiple points on the plantar surface like the one in the above figure?
The blue lines are forces and not pressure. To estimate the pressure, you will also need some stiffness and it's quite complex to model with the technology of AnyBody, which is essentially rigid-body multi body dynamics. There is no soft-tissue deformation. To put simply, if you have a pressure mat, you will not see the blue lines corresponding to the recorded plantar pressure.
