Global vs. local coordinates to drive model
Would you recommend using global or local coordinates to drive a model
with markers? For example, in the gait model, was that driven by
markers as they move through a global environment or locally in
comparison with each other?
Which would you recommend?
Sarah
Hi Sarah
It is a good question
The gait model is driven using the global coordinate system for
measuring between the human model markers and the free floating
measured markers, except for the Metatarsal marker which is using
the
local. This works well for the gait model since it does not turn
around wrt. the global coordinate system.
In general i think the local formulation is the best so the local
coordinate systems of the bony segments should be used. We have done
some experiments on a model where we did that and it worked out
well.
The advantage of this setup is that when the person turns around
wrt.
to the global coordinate system this will not affect how the model
is
driven model. If it uses the global one it will have a big impact.
So introduce a Ref=0 in the AnyKinLinear’s you are using for driving
the model. Then it will use the first of the reference frames in the
measure as the reference coordinate system.
AnyBody Support
— In anyscript@yahoogroups.com, “Sarah R. Sullivan”
<sarsulli@e…>
model
> Thanks,
> Sarah
Just to make sure I get this right. Let’s say a set of markers that
are reference to a GlobalMarkerRef and a model that is referenced to a
GlobalRef. If, for the linear measure:
  • I use a local referencing system with the model node listed first,
    Anybody will convert the marker’s coordinate from the GlobalMarkerRef
    to the NodeRef and will compare the position of the marker to the
    origin of the NodeRef.
  • I use a global referencing system, Anybody will convert both the
    node position and the marker position to the GlobalRef and compare the
    distance between the two.
Is that right?
Jean-Olivier
— In anyscript@yahoogroups.com, “AnyBody Support” <support@a…> wrote:
> Hi Sarah
> the
> well.
> wrt.
> is
> Best regards
> AnyBody Support
> <sarsulli@e…>
> model
> > Thanks,
> > Sarah
Hi Oliver
I will try to explain
If you write
AnyKinLinear marker={
AnyRefFrame &marker = …
AnyRefFrame &markeronhuman = …
this measure will measure the difference in x,y,z between the two
markers using the global reference system,
Ref=0;
markers using the marker reference system. In the gait model it will
have same orientation as the global ref so this will measure the
same way as the first example
AnyRefFrame &humanmarker = …
Ref=0;
markers using the humanmarker reference system. This is very
different since this coordinate system changes orientation when the
leg is moving.
For more details please look up AnyKinLinear in the reference manual
http://www.anybodytech.com/fileadmin/doc/AnyBodyRefManual.pdf
Please do not hesitate to ask again if you have further questions.
AnyBody Support
— In anyscript@yahoogroups.com, “jeanolivierracine” <jean-
olivier.racine.1@e…> wrote:
> Hi,
to a
> - I use a local referencing system with the model node listed
first,
GlobalMarkerRef
> - I use a global referencing system, Anybody will convert both the
the
> Is that right?
> Jean-Olivier
wrote:
> > Hi Sarah
using
> > the
local
done
> > well.
> > wrt.
model
> > is
impact.
driving
the
> > Best regards
> > AnyBody Support
> > <sarsulli@e…>
a
> > model
by
> > > Thanks,
> > > Sarah
Great, sounds good, I get the idea.
But it brings up another question:
Suppose we go back to the second example, but use it in a driver context:
AnyKinEqSimpleDriver markerdriver = {
Ref=0;
MeasureOrganizer = {0, 2};
Now, suppose humanmarker has a different orientation than the
GlobalRef. When I use the organizer and specified {0, 2}, was I
refering to the GlobalRef or the humanmarker reference system? In
other words, is it the X and Z coordinates according to the
humanmarker or GlobalRef that I will be driving? The scope suggests
that it will be GlobalRef, but again…
> Hi Oliver
> If you write
> Ref=0;
> Ref=0;
> leg is moving.
> Best regards
> AnyBody Support
> > Hi,
> to a
> first,
> GlobalMarkerRef
> the
> > Is that right?
> > Jean-Olivier
> wrote:
> > > Hi Sarah
> using
> > > the
> local
> done
> > > well.
> > > wrt.
> model
> > > is
> impact.
> driving
> the
> > > Best regards
> > > AnyBody Support
> > > <sarsulli@e…>
> a
> > > model
> by
> > > > Thanks,
> > > > Sarah
Hi Oliver
It will drive x difference and z difference between the to nodes,
using the coordinate system in the humanmarker, not the global
cooridnate system. So the the coordiantesystem will be moving with
the human bone and change orientation when the person moves.
This setup is good because you will always drive the model in the
same way even if he rotates in the global reference system. This is
not the case when the globalref is being used.
As an example take the metatarsal maker on the foot if you drive
this is x direction of the foot coordinate system, which points
upwards for a stading model. This dof will be good for driving the
ankle flexion no matter how the model is orientatet in the
globalref.
AnyBody Support
context:
> Ref=0;
wrote:
> > Hi Oliver
> > If you write
two
> > Ref=0;
two
will
> > Ref=0;
two
the
> > leg is moving.
manual
questions.
> > Best regards
> > AnyBody Support
> > > Hi,
that
referenced
> > to a
> > first,
> > GlobalMarkerRef
the
the
compare
> > the
> > > Is that right?
> > > Jean-Olivier
<support@a…>
> > wrote:
> > > > Hi Sarah
for
floating
> > using
> > > > the
turn
> > local
have
> > done
out
> > > > well.
around
> > > > wrt.
> > model
> > > > is
> > impact.
> > driving
frames in
> > the
> > > > Best regards
> > > > AnyBody Support
> > > > <sarsulli@e…>
drive
> > a
> > > > model
driven
> > by
locally in
> > > > > Thanks,
> > > > > Sarah
