Hi Peter
I have uploaded a new version of your gait TLEM model it is named
Trial_TLEM_st.zip
It is not perfect yet though…
First of all I did not yet manage to make it run through the “SCALE” option
set in the Study.txt file, but it runs the POSONLY. This means that it has
optimized the joint angles to make the best possible fit with the recorded
data, but it has not optimized the marker location and segment lengths.
Furthermore a small temporary fix was needed in the
JoitnAndDriversOptimized.any file, since it that the gaitaplication2 returns
a knee angle exactly 180 off, compared to the way the AnyBody model measures
the knee angle.
This has been fixed by these lines which are a neat way of adding a constant
to a measure.
AnyKinMeasureLinComb KneeFix =
AnyKinMeasureOrg RightKneeFlexion1 = {
AnyKinRotational KneeRot={
AnyRefNode &ThighNode =
…HumanModel.Right.Leg.Seg.Thigh.KneeJoint;
AnyRefNode &ShankNode =
…HumanModel.Right.Leg.Seg.Shank.KneeJoint;
Type=RotAxesAngles;
MeasureOrganizer={0};
Coef = {{1}};
Const= {pi};
Inside the GaitApplication everything is ok, it when it writes out the
angles that it goes wrong.
Right now I am not sure what exactly goes wrong with the SCALE analysis, it
seems that the input files etc are all ok, but after a number of iterations
it fails as you describe. Until this is resolved I hope you can use the
results from the POSONLY analysis.
I think the next things to try out are different starting guess on segments
lengths and locking of more of the free markers, by changing the
optimization settings.
Of Peter Worsley
Sent: 11 September 2008 17:33
Subject: RE: [AnyScript] GOM and TLEM model
Hi Micheal,
thank you for putting up the new GaitApplication, I have now been able to
run GOM in my models. But there seems to be a script error resulting in high
MaxKinError despite getting the MarkerPlacemetStudy to a reasonable level of
accuracy. The opt model also is causing a problem with finding initial
positions, and I can’t seem to get it to follow alterations to the mannequin
file. I noticed a similar pattern in the GaitUniMiami model as well. I’ve
put the model up on the forum.
Your thoughts would be greatly appreciated.
Peter
— On Tue, 9/9/08, Michael Skipper Andersen <msandersen60@
Date: Tuesday, 9 September, 2008, 1:41 AM
Hey Peter,
It would of course be useful if you want to try it out on some of your data.
Just out of curiosity, did you apply the “old” GaitApplication2 and
lower extremety model to your data already?
I will wrap up a version of the new GaitApplication2 that supports the new
TLEM
model and upload it to the filesection some time this week.
Michael
To: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.comFrom> ps.comFrom:
peter.worsley@ <mailto:peter.worsley%40yahoo.co.ukDate> yahoo.co.ukDate:
Mon, 8 Sep
2008 13:12:52 +0000Subject: RE: [AnyScript] GOM and TLEM model
Hey Michael, There is no real rush for the GOM application for TLEM. I was
just
going to run through some comparison data sets to see how the model changes
with
the new anthropometrics. I would be happy to try the GaitApplication out on
my
models if it would help you in any way. best wishesPeter — On Thu, 4/9/08,
Michael Skipper Andersen <msandersen60@ <mailto:msandersen60%40hotmail.com>
hotmail.com> wrote:From: Michael
hotmail.com>Subject: RE: [AnyScript] GOM
and TLEM modelTo: anyscript@yahoogrou
<mailto:anyscript%40yahoogroups.comDate> ps.comDate: Thursday, 4 September,
2008,
6:38 PMHey Peter,The version of GaitApplication2 that both supports the old
gait
model as wellas the new TLEM model has already been developed but has just
not
been put outfor download yet. I can upload it right away in its current
state.
Documentation for the inputlangange for the new leg is still lacking though
and
will probably not comebefore together with next repository update. However,
if
you want to try it outstraight away, I can upload it in its current form.
Please
let me know if youwould like that?The new input language should be possible
to
deduct from theDataForConfigFile.any file in the new gait application using
the
TLEM leg.I hope this helps.Best regardsMichael Skipper AndersenThe AnyBody
Research ProjectTo: anyscript@yahoogrou
Wed, 3 Sep2008 14:18:37 +0000Subject: [AnyScript]
GOM and TLEM modelDear all, I have been trying to import some of my own data
sets into thenewTLEM model, I have set the model up to run successfully but
when
I usethe GOMapplication it does not recognise the new talus segment
(wherethe
ank markersare positioned). Will the GOM be upgraded toincorperate the new
segment or is itworth me using previouslycalculated optimised marker
positions
in my models?bestwishes
__________________________________________________________Explore the seven
wonders of the
worldhttp://
<worldhttp://search.msn.com/results.aspx?q=7+wonders+world&mkt=en-US&form=QB
RE>
search.msn.com/results.aspx?q=7+wonders+world&mkt=en-US&form=QBRE[Non-text
portions of this message have been
removed]------------------------------------Users of the AnyBody Modeling
System
help each other create biomechanicalmodels in the AnyScript language.Yahoo!
Groups Links[Non-text portions of this message have been removed]
Discover the new Windows Vista
http://search.
<http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE>
Users of the AnyBody Modeling System help each other create biomechanical
models in the AnyScript language.Yahoo! Groups Links
