Graphical quality of AnySurf*
Søren:
I have a simple question.
The graphical quality of the surface created by AnySurf* function is
poor and cannot be improved. For example, I created a cylinder using:
AnySurfCylinder Cylinder_Sample =
Radius = 0.022;
Length = 0.10;
// CapRatio = 0.01;
AnyDrawParamSurf tool =
RGB = {0.8, 0.5, 0.5};
ScaleXYZ = {1, 1, 1};
Transparency = 0.3;
Face = 20;
WireFrameOnOff = Off;
I have changed the value of “Face” from 2 to 20, the displayed shape
is the same – the cylinder is not round. It it possible to improve
the graphical quality?
John
Hi John
I am sorry but there are currently no way to improve the display of the
cylinder object.
The Face variable will not make the cylinder look nicer it is meant to
control the normal of the triangles used when drawing the cylinder.
If the you would like to have more detail on the cylinder the quick fix is
to create a unity sized cylinder in a CAD program and import it as an .stl
file. scaling it to the proper size using the ScaleXYZ property. In this way
you can use the same CAD file of cylinder CAD multiple times.
This is the explanation from the manual:
AnyVar Face
Normal direction specification. Outwards normal is defined by the surface
triangles’ vertex numbering as ’0’ means clockwise, ’1’ means
counter-clockwise, ’-1’ means both sides will be drawn on all object
surfaces. Any other value implies automatic selection. (=2)
Of johnzengwu
Sent: 27 October 2008 17:16
Subject: [AnyScript] Graphical quality of AnySurf*
Søren:
Radius = 0.022;
Length = 0.10;
// CapRatio = 0.01;
Transparency = 0.3;
Face = 20;
John
Søren:
Thanks for the response. It’s a quick fix. I generated the cylinder
mesh using other software and imported into AnyBody as STL. It looks
fine now.
John
— In anyscript@yahoogroups.com, AnyScript Support
<anyscriptsup@…> wrote:
> Hi John
the
> cylinder object.
to
fix is
an .stl
this way
> AnyVar Face
surface
> triangles’ vertex numbering as ‘0’ means clockwise, ‘1’ means
> counter-clockwise, ‘-1’ means both sides will be drawn on all object
> Best regards
> _____
On Behalf
> Of johnzengwu
> Søren:
is
using:
> Radius = 0.022;
> Length = 0.10;
> // CapRatio = 0.01;
> Transparency = 0.3;
> Face = 20;
shape
> John
