For both my load carriage task and lifting task, the graphs are showing the inverse. For instance, knee flexion is displaying knee extension.
How do I rectify this problem?
Kirsten
Kirsten
It seems that some of AnyBody’s joint angle conventions may be different from what you think.
I would recommend you to check our ‘StandingModel’ to check which value you can see there.
Thanks for the response. Will look at that.
Quick question, is the mocap model validated?
In other words would I need to validate my lifting and lowering task and load carriage task if using the mocap model?
This is a more “ethical” question. Several previous users have made simulation and compared it to experimental data in order to validate this MoCap model. However, as soon as you change a single line, it is not the same model anymore. This means the principles used in this model, the individual parts should be validated.
