HI
I have a physical model in my lab of a 2D lumbar spine with a
loadcell at the base. I thought it would be possible to input these
reactions into the model, similar to the gait example. The diffrence
is that the base of my model is static. I wrote the following simple
code, just to try to implement the loadcell reactions. However, my
model does not load the muscles. Can you please help me understand
how to appropriately apply these reactions.
Liss
Main = {
// Global Reference Frame
AnyDrawRefFrame DrwGlobalRef = {
ScaleXYZ = {.1, .1, .1};
RGB = {0,1,0};
AnyRefNode Ground = {
sRel = {0,0,0};
AnyDrawNode SN = {
ScaleXYZ = {.002,.002,.002};
AnyRefNode Hz = {
sRel = {1,1,0};
AnyDrawNode SN = {
ScaleXYZ = {.02,.02,.02};
AnyRefNode Hz2 = {
sRel = {-1,1,0};
AnyDrawNode SN = {
AnyRefNode Vt = {
sRel = {0,2,0};
AnyDrawNode SN = {
}; // Global reference frame
AnyFolder Segs = {
////Define dummy segment
AnySeg Ground={
r0={0,0,0};
Mass = 0;
Jii = {0,0,0};
AnyRefNode GRF={ sRel={0,0,0};};
AnySeg L5 = {
r0 = {0, 0.5, 0};
Mass = 2.0;
Jii = {.02,.01,.01};
AnyRefNode Top = {
sRel = {0,0.5,0};
AnyDrawRefFrame DrwNode = {
AnyRefNode Bottom = {
sRel = {0,-0.5,0};
AnyDrawNode DrwNode = {
AnyDrawSeg Bar = {};
AnyFolder Muscles = {
// // Simple muscle model with constant strength = 300 Newton
AnyMuscleModel MusMdl = {
F0 = 300;
AnyViaPointMuscle MuscleVt = {
AnyMuscleModel &MusMdl = ..Muscles.MusMdl;
AnyRefNode &Org = ..Segs.L5.Top;
AnyRefNode &Ins = ..GlobalRef.Vt;
AnyDrawMuscle DrwMus = {};
AnyViaPointMuscle MuscleHzR = {
AnyMuscleModel &MusMdl = …Muscles.MusMdl;
AnyRefNode &Org = …Segs.L5.Top;
AnyRefNode &Ins = …GlobalRef.Hz;
AnyViaPointMuscle MuscleHzL = {
AnyRefNode &Ins = ..GlobalRef.Hz2;
//_____________JOINT DEFINITIONS______________________
AnyFolder Jnts = {
AnyRevoluteJoint Base = {
Axis = z;
AnyRefNode &GN = …GlobalRef.Ground;
AnyRefNode &L5Node = …Segs.L5.Bottom;
}; // L5S1 joint
AnyKinEqPolynomialDriver L5S1Driver = {
AnyRevoluteJoint &Jnt = .Jnts.Base;
PolyCoef = { {0.2 } };
Reaction.Type = {Off};
AnyFolder Moments = {
AnyForceMomentMeasure2 L1Reaction = {
AnyForceBase &Mext = Main.MyModel.Muscles.MuscleVt;
AnyForceBase &M1 = Main.MyModel.Muscles.MuscleHzR;
AnyForceBase &M2 = Main.MyModel.Muscles.MuscleHzL;
// AnyRefFrame &Ref = Main.MyModel.Segs.L5.Top;
AnyRefFrame &Ref = Main.MyModel.GlobalRef;
AnySeg &L1=Main.MyModel.Segs.L5;
////Kinematic Measures________
// Place the L5 segment on the ground
AnyKinEqSimpleDriver GroundLinConstraint ={
AnyKinLinear Lin = {
//Ref=-1;
AnyFixedRefFrame &Ground = Main.MyModel.GlobalRef;
AnyRefFrame &L5 = …Segs.Ground;
DriverPos = {0,0,0};
DriverVel = {0,0,0};
Reaction.Type = {Off,Off,Off}; // Provide ground reaction
forces
AnyKinEqSimpleDriver GroundRotConstraint ={
AnyKinRotational Rot = {
Type =RotAxesAngles;
forces
AnyReacForce GroundContactForce={
AnyKinLinear Lin={
Ref=0;
AnySeg &ref1=Main.MyModel.Segs.Ground;
AnyRefNode &ref2=Main.MyModel.Segs.L5.Bottom;
AnyKinRotational Rot= {
Type=RotVector;
//_____________________________
AnyForce3D ForceOnGround ={
// AnyFunInterpol force ={
// Type=Bspline;
// BsplineOrder = 8;
// FileName =“Force.txt”; //t, Fx, Fy, Fz
F={0,-20,0};
//AnyMoment3D MomentOnGround ={
//// AnyFunInterpol moment ={
//// Type=Bspline;
//// BsplineOrder = 8;
//// FileName = “Moment.txt”;
// AnySeg &ref1=Main.MyModel.Segs.L5;
// M={0,0,0};
}; // MyModel
// The study: Operations to be performed on the model
AnyBodyStudy MyStudy = {
AnyFolder &Model = .MyModel;
RecruitmentSolver = MinMaxSimplex;
Gravity = {0.0, 0, 0.0};
}; // Main
