Hello, I had studied Anybody about inverse dynamic analysis.
I collected muscle load data by muscle amplitude.
Then, I want know how to get L5/S1 compression data such as 3DSSPP.
How can I get those data? I'm using AMMR ver 2.3.1.
Thank you!
Thank you!
Hi @shim2906 and welcome to the forum!
The spine joint reaction forces are located Main.HumanModel.BodyModel.SelectedOutput.Trunk.JointReactionForce and here you can the L5SacrumProximoDistalForce which is the compression.
Bjørn
