I want to create an AnyRefNode A on object B. A has the same location as another AnyRefNode C on object D.What could I do to make it? Thanks!
Best,
TJ
Best,
TJ
Assuming you have two segments each having their initial position (r0 and Axes0) as default values. Then you would simple define a node on each segment having the same sRel value, then the nodes would be aligned.
If the initial positions are not the same or if the segments use differenr coordinate systems you would need to account for this in the specification of sRel.
