How know marker's coordinates
hi ~ Anybody team
I want to find the location of the blue marker and move the coordinate point of the red marker.
What should I do?
I know how to modify the coordinate points of the red marker.
I want to know the position of the blue marker on the X, Y, and Z axes.
Hi Minjihyun,
If you double click on the blue marker in the model view, you will see the model tree explore to the drawing object of the corresponding kinematic measure. If you scroll up a little bit in the model tree, you will find Pos value of the kinematic measure. This is the difference in the current time-step between the blue and red marker in the X,Y,Z axis for the corresponding marker.
I hope this helps!
