How to attach Solidwork2anybody file with Anybody Human model
I extract solidwork2anybody file to anyscript. later I got my model with Anybody human. Unfortunately I am not able to attach my exoskeleton along with human arm. Please suggest the solution.
Usually you have to define both kinematic and kinetic connections between human and your exoskeleton.
It means that your exoskeleton model should have several reference nodes which will be used for those connections.
And you should count how many degrees of freedom you exoskeleton model has.
After that, you should define several constraints according to that DOFs.
If you have some problems then please try to upload your model in the debug section:
Then we will try to have a look on that model.
