I am researching into Body metabolic rate and fatigue. I am a beginner on AnyBody.
I would like to replace the model in MetabolicModel2 and then calculate the output to Pmet2 to compare the results with Pmet.
Within the scope of InverseDynamicStudy, please set the value for MetabolicModel2. As you can see in the model tree, the object exists in your model but it is not explicitly defined in the script. So, when you try to locate in AnyScript, it takes you to the parent object.
