2. And I noticed that the hip joint refers to HipJoint, not HipJointAnatomicalFrame. So if I want to change the hip center position in anatomical frame , the following code should be corrected:
The anatomical frame is mostly used for scaling and not as a joint node.
Please have a look at the THA model, in there we have designed a way to exchange the “normal” hip joint and replace it by a modified hip joint with a different center.
Dear Amir,
Thank you for your reply.
Now I know how to change the position and I have got the code to change the position:
AnyOperationSetValue ChangeCupPos=
