Dear Support,
I have an question in comparing the muscle force with the muscle force in other literature. As you know every block of muscle in AB contains several parts. for example, the GluteusMedius contains GluteusMediusAnterior1,GluteusMediusAnterior2…GluteusMediusAnterior6,and also contains GluteusMeiusPosterior parts. But in literature, the authors just metioned “GluteusMedius”. So I don’t know which part I should choose to compare with other data? Choose the maximum?
I have added the AnyForceMomentMeseasure2 to my model to measure the GluteusMedius muscle force. Just show as follows. Can you help check it to ensure the results?
many thanks
That looks good, except you need to switch off the IncludeGravity flag. And the cumulative force will be reported in the global reference frame. Change it to be something else if this is not intended.
