I'm Liam.
I work with motion capture models. I frequently need to modify parameters to ensure the markers fit correctly. Unfortunately, this is a repetitive task that requires me to load the model multiple times. The problem is that the model loading process is slow, which consumes a lot of time. I'm wondering if there is a way to load the model without including the muscle components. This could potentially help speed up the loading time and improve my efficiency.
Thank you in advance.
