Hi Soren,
Thank a lot . I am running tests on the model .I will get back to you for more
queries.Thank you again .
Sincerely,
Shreeganesh Sudhindra
— On Mon, 3/2/09, AnyScript Support <anyscriptsup@anybodytech.com> wrote:
From: AnyScript Support <anyscriptsup@anybodytech.com>
Subject: RE: [AnyScript] How to resolve this statistically inderminate problem
Date: Monday, March 2, 2009, 4:03 PM
         Hi Shreeganesh
I have made some changes in the model and uploaded it again using the name
“testfiledumbV2�
The problem was the following:
You have added 2 new segments, this adds 12 rigid body dof to the system
You then added three revolutejoints and a driver of one of them this is 16
kinematic constraints.
I have changed the should exo joint to be a spherical, the elbow to a
revolute and the palm to a cylindrical this gives in total 3+5+4=12
constraints which was needed… the driver I have removed.
When doing this kind of model it is always important to keep an eye on the
dof balance, we often recommend doing a small stick figure sketch of the
model showing the joint types etc…
From: anyscript@yahoogrou ps.com [mailto:anyscript@yahoogrou ps.com] On Behalf
Of shreeganesh_ sastra
Sent: 27 February 2009 19:34
Subject: [AnyScript] How to resolve this statistically inderminate problem
Hi Sylvian,
I have uploaded the file as suggested.I would request you to have a
look at it and help me resolve the issue.Thank you.
Sincerely,
Shreeganesh . S
Earlier Message :
I am Shreeganesh Sudhindra .I am currently working on the arm curl
model. It is my aim to improvise on the existing model and come up
with an exo skeleton for the same. My issue is that while the model
loads it says " Model Warning: Study ‘Main.ArmStudy’ contains more
reaction forces than rigid-body degrees of freedom of the segments.
The model may be statically indeterminate. There are 25 reactions and
only 24 rigid body degrees of freedom. " .I have tried reducing the
constraints one by one and I am still unable to figure out where I am
going wrong .I have attached my anyscript with this post.I would
appreciate it if you could throw some light onto this issue.Thank you.
Sincerely ,
Shreeganesh. S
