Hi AnyBody,
I am trying to use the open-source C3D data from website “https://doi.org/10.6084/m9.figshare.14420756” to drive the human body model. However, when the "RunMotionAndParameterOptimizationSequence" operation is executed, it prompts that the kinematics analysis failed.
#### Macro command : RunMotionAndParameterOptimizationSequence(5:5)> run
5.0) Kinematics (Operation: Main.Studies.MotionOptimization.Kinematics):
5.0.0) PreOperation (Operation: Main.Studies.MotionOptimization.Kinematics.PreOperation):
5.0.0.0) InitialConditions (Operation: Main.Studies.MotionOptimization.InitialConditions):
5.0.0.0) ...Design variables have been updated.
5.0.0.1) ...Load-time positions have been re-established.
5.0.0.2) ...Kinematic analysis completed.
5.0.0.3) ...Dependent variables are fully updated.
5.0) Kinematic analysis...
Failed to resolve kinematic constraints. Newton relaxation too small. (final kin. error = 9.151032E-005)
Constraint no. 7 above error tolerance 0.000001, error = 0.000001.
Constraint no. 10 above error tolerance 0.000001, error = 0.000004.
Constraint no. 11 above error tolerance 0.000001, error = 0.000003.
Constraint no. 12 above error tolerance 0.000001, error = 0.000002.
Constraint no. 14 above error tolerance 0.000001, error = 0.000011.
Constraint no. 15 above error tolerance 0.000001, error = 0.000014.
Constraint no. 16 above error tolerance 0.000001, error = 0.000011.
Constraint no. 17 above error tolerance 0.000001, error = 0.000007.
Constraint no. 18 above error tolerance 0.000001, error = 0.000007.
Constraint no. 19 above error tolerance 0.000001, error = 0.000009.
Constraint no. 20 above error tolerance 0.000001, error = 0.000011.
Constraint no. 23 above error tolerance 0.000001, error = 0.000001.
Constraint no. 28 above error tolerance 0.000001, error = 0.000001.
Constraint no. 29 above error tolerance 0.000001, error = 0.000003.
Constraint no. 30 above error tolerance 0.000001, error = 0.000004.
Constraint no. 35 above error tolerance 0.000001, error = 0.000003.
Constraint no. 36 above error tolerance 0.000001, error = 0.000005.
Constraint no. 37 above error tolerance 0.000001, error = 0.000007.
Constraint no. 42 above error tolerance 0.000001, error = 0.000004.
Constraint no. 43 above error tolerance 0.000001, error = 0.000007.
Constraint no. 44 above error tolerance 0.000001, error = 0.000009.
Constraint no. 49 above error tolerance 0.000001, error = 0.000005.
Constraint no. 50 above error tolerance 0.000001, error = 0.000009.
Constraint no. 51 above error tolerance 0.000001, error = 0.000012.
Constraint no. 56 above error tolerance 0.000001, error = 0.000006.
Constraint no. 57 above error tolerance 0.000001, error = 0.000012.
Constraint no. 58 above error tolerance 0.000001, error = 0.000015.
Constraint no. 63 above error tolerance 0.000001, error = 0.000006.
Constraint no. 64 above error tolerance 0.000001, error = 0.000013.
Constraint no. 65 above error tolerance 0.000001, error = 0.000017.
Constraint no. 67 above error tolerance 0.000001, error = 0.000015.
Constraint no. 68 above error tolerance 0.000001, error = 0.000019.
Constraint no. 69 above error tolerance 0.000001, error = 0.000004.
Constraint no. 92 above error tolerance 0.000001, error = 0.000002.
Constraint no. 97 above error tolerance 0.000001, error = 0.000001.
Constraint no. 105 above error tolerance 0.000001, error = 0.000007.
Constraint no. 108 above error tolerance 0.000001, error = 0.000019.
Constraint no. 109 above error tolerance 0.000001, error = 0.000004.
Constraint no. 110 above error tolerance 0.000001, error = 0.000004.
Constraint no. 111 above error tolerance 0.000001, error = 0.000007.
Constraint no. 112 above error tolerance 0.000001, error = 0.000034.
Constraint no. 113 above error tolerance 0.000001, error = 0.000001.
Constraint no. 114 above error tolerance 0.000001, error = 0.000056.
Constraint no. 115 above error tolerance 0.000001, error = 0.000092.
Constraint no. 116 above error tolerance 0.000001, error = 0.000027.
Constraint no. 117 above error tolerance 0.000001, error = 0.000026.
Constraint no. 118 above error tolerance 0.000001, error = 0.000039.
Constraint no. 119 above error tolerance 0.000001, error = 0.000006.
Constraint no. 120 above error tolerance 0.000001, error = 0.000034.
Constraint no. 121 above error tolerance 0.000001, error = 0.000009.
Constraint no. 122 above error tolerance 0.000001, error = 0.000015.
Constraint no. 123 above error tolerance 0.000001, error = 0.000010.
Constraint no. 124 above error tolerance 0.000001, error = 0.000008.
Constraint no. 125 above error tolerance 0.000001, error = 0.000005.
Constraint no. 215 above error tolerance 0.000001, error = 0.000014.
Constraint no. 216 above error tolerance 0.000001, error = 0.000012.
Constraint no. 217 above error tolerance 0.000001, error = 0.000017.
Constraint no. 218 above error tolerance 0.000001, error = 0.000011.
Constraint no. 219 above error tolerance 0.000001, error = 0.000002.
Constraint no. 220 above error tolerance 0.000001, error = 0.000014.
Constraint no. 221 above error tolerance 0.000001, error = 0.000006.
Constraint no. 222 above error tolerance 0.000001, error = 0.000025.
Constraint no. 223 above error tolerance 0.000001, error = 0.000014.
Constraint no. 224 above error tolerance 0.000001, error = 0.000012.
Constraint no. 227 above error tolerance 0.000001, error = 0.000005.
Constraint no. 228 above error tolerance 0.000001, error = 0.000006.
Constraint no. 235 above error tolerance 0.000001, error = 0.000004.
Constraint no. 236 above error tolerance 0.000001, error = 0.000005.
Constraint no. 238 above error tolerance 0.000001, error = 0.000001.
Constraint no. 253 above error tolerance 0.000001, error = 0.000008.
Constraint no. 267 above error tolerance 0.000001, error = 0.000018.
Constraint no. 268 above error tolerance 0.000001, error = 0.000018.
Constraint no. 269 above error tolerance 0.000001, error = 0.000008.
Constraint no. 270 above error tolerance 0.000001, error = 0.000009.
Constraint violations for study 'Main.Studies.MotionOptimization' :
Constraint #68 is above tolerance 1e-006, error = 0.000014, constr. #0 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #68 is above tolerance 1e-006, error = 0.000012, constr. #1 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #68 is above tolerance 1e-006, error = 0.000017, constr. #2 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #68 is above tolerance 1e-006, error = 0.000011, constr. #3 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #68 is above tolerance 1e-006, error = 0.000002, constr. #4 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #73 is above tolerance 1e-006, error = 0.000014, constr. #0 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #73 is above tolerance 1e-006, error = 0.000006, constr. #1 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #73 is above tolerance 1e-006, error = 0.000025, constr. #2 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #73 is above tolerance 1e-006, error = 0.000014, constr. #3 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #73 is above tolerance 1e-006, error = 0.000012, constr. #4 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #78 is above tolerance 1e-006, error = 0.000005, constr. #2 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Knee.Constraints'.
Constraint #78 is above tolerance 1e-006, error = 0.000006, constr. #3 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.Knee.Constraints'.
Constraint #86 is above tolerance 1e-006, error = 0.000004, constr. #2 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.PatellaFemur.Constraints'.
Constraint #86 is above tolerance 1e-006, error = 0.000005, constr. #3 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.PatellaFemur.Constraints'.
Constraint #91 is above tolerance 1e-006, error = 0.000001, constr. #0 in 'Main.Studies.HumanModel.BodyModel.Left.Leg.Jnt.PatellaMovement'.
Constraint #166 is above tolerance 1e-006, error = 0.000008, segment constr. 'Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Thigh'.
Constraint #180 is above tolerance 1e-006, error = 0.000018, segment constr. 'Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Talus'.
Constraint #181 is above tolerance 1e-006, error = 0.000018, segment constr. 'Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Foot'.
Constraint #182 is above tolerance 1e-006, error = 0.000008, segment constr. 'Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Shank'.
Constraint #183 is above tolerance 1e-006, error = 0.000009, segment constr. 'Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Patella'.
ERROR(OBJ.MCH.KIN3) : E:/AnyBodyStudy/C..6/Model/Kinematics.any(74) : MotionOptimization.Kinematics : Kinematic analysis failed in time step 73 : Failed to solve position analysis
This is very important to me, if possible, please tell me how to modify it. I use AnyBody V6.1 and the model is as follows.
C3DTest20230416.zip (2.6 MB)
Thank you in advance.
Chen
