Hello
I’m currently working with the pedal example in the repository and I’m preparing an parameter study. One parameter that I would like to study is how the pedals initial angle affects the muscle activity. The pedal is hinged at one end and driven by a AnyKinEqSimpleDriver. The data that I’m using says that the pedal should have a horizontal movement of 37mm at the foot-pedal contact node. The problem is that I can’t “stop” the driver when the pedal has moved 37mm. At first I made the simulation time, tend dependent of the pedals movement but this did not work when I tried to run a parameter study.
Does anyone out there have any tips on how to make the pedal stop after it has move a certain distance and make it compatible with the parameter study?
Erik Ejdepalm,
KTH Royal Institute Of Technology
