I want to run inverse dynamics to use c3d data.
I try to opened c3d data to use AnyBody and mokka. But I can’t open c3d data.
SO, I run inverse dynamics to use text data because my c3d data has bug?
Please tell me using text data.
I attach c3d contained bug.
Plese check this data.
I challenge to change the model .
But, I receive error message.
The message is ERROR(OBJ.FILE1) : C:/U…s/h…9/D…p/a/A…5/A…5/A…n/E…s/C…l/FilterandMocapDrivers1120.any : DataIn.FileName : Problem with file : C:\Users\haselab39\Desktop\a\AMMRV1.5\AMMRV1.5\Application\Examples\Coment_model\1.1_01_01Freposi.csv(2) : There appears to be no data point values in the first line containing data, only the parameter value was found.
This file is markers data .
I don’t understand error reason.
AMS is 1.5.
I’m trying to figure out the csv files which you’ve uploaded here before.
In your csv files, there are 41 markers from P1 to P41.
But from these points, it is hard to guess the definitions of markers.
If you see the following video for the plug-in gait marker set of VICON motion capture system, we can distinguish the markers by special names. http://vimeo.com/33160563
But in your csv file, because all marker names are such as P1 and P2, it is very hard for us to find where they are attached.
It seems that you are using Venus3D motion capture system. Do you have any manual for that system? Then it would be helpful for us.
Thanks you for message.
CSV file order is following RFHD,LFHD,RBHD,LBHD,RELB,LELB,RUPA,LUPA,
RFRA,LFRA,LFIN,LWRA,LWRB,RFIN,RWRA,RWRB,
RASI,LASI,RPSI,LPSI,T10,STRN,C7,RBAK,CLAV,
LSHO,RSHO,LTHI,RTHI,RKNE,LKNE,RTIB,LTIB
LTOE,LMT5,LANK,LHEE,RTOE,RMT5,RANK,RHEE.
Sorry, I study this model.
Thanks you message.
I can use c3d file by c3deditor.
Thanks you.
But I receive error message of ERROR(OBJ.MCH.KIN3) : C:/U…s/h…9/D…p/a/A…5/A…5/A…n/E…s/G…y/GaitFullBody1101.main.any : MotionOptimization.InitialConditions : Kinematic analysis failed in time step 0
