Hi guys,
I want to simulate the humerus coordinate system of the ISB recommandation using the second option. In this second option, the coordinate system is defined as follows:
Origin : The origin coincident with GH.
Y-axis : The line connecting GH and the midpoint of EL and EM, pointing to GH.
Z-axis : The line perpendicular to the plane formed by Yh2 and Yf, pointing to the right.
X-axis : The common line perpendicular to the Z-axis and Y-axis, pointing forward.
The Yf is the axis from the Ulna styloid node to the midpoint of EL and EM.
To do that, I proceeded in the following way:
AnySeg HumerusWu2ndOption = {
Mass = 0;
Jii = {0,0,0};
r0 =.Humerus.r0;
Axes0 = .Humerus.Axes0;
//AnyDrawRefFrame drw = {ScaleXYZ={1,1,1}*0.1;RGB={0,1,0};};
AnyRefNode Node = {
sRel = {0,0,-0.1};
//AnyDrawNode drw = {ScaleXYZ={1,1,1}*0.01;};
AnyRefNode RotNode2 = {
ARel = RotMat(pi/2,y);
AnyDrawRefFrame drw = {ScaleXYZ={1,1,1}*0.1;RGB={0,0,1};};
AnyRevoluteJoint HumerusWu2ndOptionJnt = {
AnySeg &ref0 = …Seg.Humerus;
AnySeg &ref1 = …Seg.HumerusWu2ndOption;
Axis=y;
AnyKinEq HumerusWu2ndOptionCon = {
AnyKinMeasureOrg linX = {
AnyKinLinear lin = {
AnyRefNode &ref0 = …Seg.HumerusWu2ndOption.Node;
AnyRefNode &ref1 = …Seg.Ulna.us;
Ref = 0;
MeasureOrganizer = {0};
Does it sounds correct to you ? Do I have to set the reaction force to Off in order to avoid the force to be absorbed by the constraint ?
Regards.
Pierre
