Hi Brent
Yes, the variables can only be assigned once.
So I am afraid that it is impossible to define parts of the script which can
be switched in and out using if statements.
I am not sure if it will solve your problem but there are a number of
functions available in AnyBody
eqfun equality test
ltfun larger than function
andfun and function
orfun or function
iffun if function
you can find a description of these functions in the reference manual
<http://www.anybodytech.com/fileadmin/AnyBody.2.x.x/doc/AnyBodyRefManual.pdf
Here is the description of the iffun:
This class defines a function for making conditional statements in an
expression. The function takes
three arguments. The first argument is the condition, where zero is equal to
’false’ and a nonzero
value is ’true’. The second argument is the return value in case of a true
condition and the third
argument is the return value for false.
So I guess this is not exactly what you are looking fore but maybe you can
use it for solving your problem.
Of blulrey
Sent: 16. september 2006 03:08
Subject: [anyscript] If statements
Is it possible to create if statements within AnyBody, like the if
statements in Matlab?
I was attempting to use a switch variable to create an On or Off
status, then use the status in an if statement. However, after
creating the switch variable, it cannot be reassigned.
AnySwitchVar Status = Off
Status = On <-------- AnyBody won’t compile this change in Status
I tried the same using an integer variable and got the same results.
Can an AnyBody variable only be assigned once?
Brent
