Hi all,
I am afraid it’s going to be a complicated message, I apologize in advance…
I am “playing” with AMMR_Thorax_beta, which is the AMMR with articulated thorax.
For my purposes, I need to get some measurements after having run initial conditions, for example the position of a particular segment, and then I need to re-use these measurement to adjust the position of other segments to get a new initial condition which will be the starting point for running the inverse dynamics (I hope it’s clear).
Since I have to reproduce these steps for many cases, I would like to avoid the multiple re-running and the manually operation to take measurements and to modify all the required anyfiles.
Is there, then, a way to prevent all of this?
Could I create, for example, a second study that uses the measurements taken from the first running of ICs to set second ICs?
where source contains the measures I want to use and target the destination, but actually in T12_orientation (from target), after running Study2.InitialConditions, there are not the new values… it seems that it doesn’t import them at all.
I even tried by typing some numbers, instead of importing that from the Measurement file, as in the following:
AnyBodyStudy Study2 = {
I figured out why it was not working, but now an error message appears, which states:
‘SetValue’ operation on this value-object is not allowed.
The object in question is an AnyVec3 one, defined at the beginning of the file Buckle.any.
I checked in the ref manual and the operation AnyOperationSetValue set the value of AnyValue-objects, which should be the same as AnyVec3.
What do you think it might be the problem?
