i have a question about the connection between the initial position and
the mannequin. every time when I set the initial position all my
setting from the mannequin get neglected. for example:
I positioned the model so that all the nodes coincide with the markers.
then, when I set the initail positions the posture of the model gets
back to a completely differnt and wrong position!!
This is most probably because your drivers are not using the data from the
mannequin file. The simple drivers of the StandingModel for example are
taking their values directly from the mannequin file. In that case the
posture of the model when running SetInitialCondition is the same as the
initial position at the loading time.
So you should either make the pos value of the driver point to the values of
the mannequin file, or make sure that the value for the first time step of
the driver is equivalent (or close enough) to the value of the mannequin
file.
whats wrong?
thx,tom
