Input ligament into knee ?
Hi All
My research is analyze ligament of knee but in repository7.1 not have example of
ligament so I will build ligament into knee.
How I will input ligament into knee in demo kneeload.main.any ?
How I will build node of ligament and I will edit code ?
You can explain me about step of edit code kneeload.main.any for analyze force
in ligament knee.
Thank you
best regards
Wongsakorn Phakdeepinit
Thammasat University
Hi Wongsakorn,
Basically you have to define new AnyRefNodes on the segments you want to
connect, e.g. on the Thigh and Shank. Then you have to define the geometry
with an AnyViaPointLigament and define the material behaviour with
AnyLigamentModelPol. An important step is the calibration of the slack
length. Please have look at the tutorial on ligament modeling
(http://www.anybodytech.com/index.php?id=682). Here you can find an example
on the detailed steps.
Sebastian
Of w_phakdeepinit
Sent: 19. marts 2009 10:07
Subject: [AnyScript] Input ligament into knee ?
Hi All
example of ligament so I will build ligament into knee.
force in ligament knee.
Thank you
best regards
Hi Sebastian
 I have problem about build ligament.If I have node will build node for
insertion node and origin node, but How I don’t know build ligament.In head of
AnyViaPointLigament and AnyLigamentModelPol where I don’t know put it of in
anybody file (kneeload.main.any).
 This time step one I try edit code easy for build node ligament. I don't know
real parameter of node, but I will make sample it.You can advice me about write
code of ligament.I would like example for build ligament in anybody file
or you can explain step of build ligament.
 I study of follow this link
and study Demo.Ligament.any ,but How I don’t know edit code in anybody file
(kneeload.main.any)
Thank you
Best Regards
— In anyscript@yahoogroups.com, AnyScript Support <anyscriptsup@…> wrote:
> Hi Wongsakorn,
> Best regards,
> Sebastian
> _____
> Of w_phakdeepinit
> Hi All
> Thank you
> best regards
