hi all, started using this software, and am wondering if anyone has an
example of how to enter position data into the drivers, i want to be
able to move for instance the end of a link from point to point for
each time specified,
using the squat example from the software package I was able to use
the anyKineqInterpolDriver and insert the angle with repect to time,
but i want to insert Cartesian Positions and time data, anyone have a
simple example of this?
First of all welcome to the group.
What you need to do is to add a node at the segment you want to drive
and then drive that node with your coordinates. There is a tutorial on
how to apply kinematic measures to segment here: http://www.anybodytech.com/501.0.html
Hopefully it is enough info, else feel free to write again:)
Christian, AnyBody Support
