Hi everybody
I’m Christine Schaerer, a graduand in human movement sciences at the
Swiss Federal Institute (ETH) in Zürich. The topic of my diploma
thesis will be the strain distribution in the femur during gait.
Therefore I want to couple the AnyBody-model with an FE-Model of a
femur. That means, I will use AnyBody to calculate the muscle forces
at specific moments during gait cycle and impose them into my FE-
Model of the femur.
The problems are as follows: I will use the kinematic datas from a
previous study. As CT-Scans from the lower limb of this proband are
not available, my FE-model is built on a CT-Scan of a cadaver. Thus,
the dimensions of the cadaver are different from the ones of the
proband, and these are again different from the ones of the AnyBody
model.
The question is now: what is now the smartest way to drive my model?
My idea was to define the exact position of the ankle according to
the kinematic datas, and then drive the angles between the segments.
This way, I won’t have troubles with the different dimensions of the
segments, will I? Is this practicable and reasonable?
In natural gait, there will also be ab/abduction and rotation in the
ankle and the knee, but these two joints are simulated as hinge
joint. How should I handle these further DoF?
I’ve looked at your gait example and read the comments about the
ground reaction force. But I still don’t understand how to impose the
varying direction and amplitude of the force.
As I want to use my own bone model of the femur I have to do quite a
lot of adjustment to the AnyBody model, i.e. scaling the segment,
adapt the muscle attachment etc.
Hence I have a few questions to the body model: How did you determine
the centre of mass (expecially the x- and z-coordinates (femur,
pelvis)) and the location of the knee joint (is it the midpoint
between lateral and medial epicondyles?)? And how are the segment
coordinate systems set (using the ISB standards and then transferred
to the center of mass?)?
Thanks a lot for your help.
Kind regards
Christine
