Join reaction forces in gait analysis
Hello everyone,
I am currently working with Anybody using the Full body Gait model. I manually added the ground reaction forces via a .txt file instead of using force plates, because we used pressure insoles. Everything worked fine, but the resulting joint reaction forces for the joints of the lower limbs seem to be way too high. They reach up to 5.000N and, if i read correctly, should be around 800-1.000N.
Is there a common mistake I made or is my research about "normal" joint reaction forces wrong?
Hi Tabea,
I can think of a couple of issues:
  1. With the pressure mat, you get the normal force. How are you taking care of the ground reaction force in the medial-lateral and anterior-posterior directions?
  2. Have you checked that the forces you are inputting in the model are sensible? Are they comparable to what you would see if you had a force plate?
Thanks for the quick answer!
  1. I am using pressure sensing insoles, and only recieve the force in the proximo-distal direction. I am not using the forces in medio-lateral or anterior-posterior directions
  2. The ground reaction forces are different in each person but are around 700-1100 N per leg (because of a tibial fracture the other leg is recieving less froces around 0-500N)
Hi Tabea,
I think it could be worth it to add some kind of GRF prediction using the normal force from the pressure insoles.
Which joint are you looking at for the joint reaction force? I assume, you are looking at the compression force and I think your estimate of 800-1000N is too low. For sure, the joint reaction force will be more than the body weight. It's not unusual to see ankle compression force around 5 times the body weight in gait analysis.
Hi Dave,
I started with the GRF predicition and also included it in the beginning, but the values are quite similiar with and without GRF prediciton!
I am mainly looking at the knee and ankle forces.
Are there any free accesible values for Joint reaction forces in normal gait using Anybody? I find it quite hard to research good papers about this topic :slight_smile:
Hi Tabea,
You can look at one of the c3d mocap models where we have GRF from force plates, for example: Simple Lower extremity model — AMMR v3.0.4 Documentation
But, of course, ideally you should search for some literature to get an overview, and not depend on values from a single trial.
