vikaskaul
(vikaskaul)
November 20, 2014, 9:45pm
1
Dear experts,
I notice that the elbow joint constraints are violated during replay of the results of a simulation performed a few days ago.
Here’s my procedure to replay the saved results:
Open AnyBody
Open the MoCap model
Turn the Inverse Dynamics switch on (if it is not on already)
Load the model
In the model tree, go to Studies->InverseDynamicStudy->Output and Load the saved results
In the operations tree, go to Studies->Inverse Dynamic Study->Replay
Am I missing something? I had visualized the saved results on the day I carried out the simulation and everything looked fine.
Thank you,
Vikas
toerholm
(Søren Tørholm)
November 21, 2014, 4:07pm
2
Hi Vikas,
If the model has been optimized you might be missing to load into the model the optimized results, which would change the bone lengths etc?
vikaskaul
(vikaskaul)
November 21, 2014, 5:19pm
3
Hi Søren,
Thank you. I thought about that right after I posted that question and I tried loading the optimized results as well but it did not help. Could you please add a line or two could to the relevant Wiki link?
Vikas
mkjung9980
(mkjung9980)
November 28, 2014, 12:04pm
4
Hi Vikas,
Here I would make some suggestions for you.
For automatic saving process of the result in the form of ‘h5’ file,
you can just change one line setting in the ‘MoCap_FullBody.main.any’ file.
#ifndef AutoSaveOption
#define AutoSaveOption 1
#endif
Then the h5 file will be saved after the execution of ‘InverseDynamicAnalysisSequence’
In the ‘InverseDynamics.any’ file, I would suggest you to add a few more lines like this:
//** Creates the RunApplication **//
Main = {
AnyOperationMacro InverseDynamicAnalysisSequence =
MacroStr =
"classoperation Main.Studies.LoadParametersOptimizationResults" + " " + strquote("Load design") + " --file=" + strformat("\x22") + "../Input/" + OutputFileNamePrefix + Main.ModelSetup.C3DFileData.NameOfFile +"-"+"OptimizedParameters.txt" + strformat("\x22"),
"classoperation Main" + strformat("\x22")+ "Update Values" + strformat("\x22"),
"operation Main.Studies.InverseDynamicStudy.InitialConditions",
"run",
"operation Main.Studies.HumanModel.Calibration.CalibrationSequence",
"run",
"operation Main.Studies.InverseDynamicStudy.InverseDynamics",
"run"
#if AutoSaveOption
"classoperation Main.Studies.InverseDynamicStudy.Output" + strquote("Save data") + " --file="+ "../Output/" + OutputFileNamePrefix + Main.ModelSetup.C3DFileData.NameOfFile + ".anydata.h5 " + "--type=Deep"
#endif
#if AutoSaveOption
Main =
AnyOperationMacro ReplayIDAnalysisSequence =
MacroStr =
"classoperation Main.Studies.InverseDynamicStudy.Output" + strquote("Load data") + " --file="+ "../Output/" + OutputFileNamePrefix + Main.ModelSetup.C3DFileData.NameOfFile + ".anydata.h5 " + "--type=Deep",
"operation Main.Studies.InverseDynamicStudy.Replay",
"run"
#endif
After adding these lines, then you can seee ‘ReplayIDAnalysisSequence’ operation in the Operations tree.
Then you can execute this operation sequence for reply with proper pre-loaded scaling.
I hope this may help you.
vikaskaul
(vikaskaul)
December 1, 2014, 5:30pm
5
Thank you very much, Moonki. That piece of script was very helpful!
Vikas
