Hello everybody,
I'm working in a simulation of hamstring exercises, this exercises consist in recreate a knee flexion, with 2kg in foot while thigh is vertical. My objective is observe activation in hamstring and coactivation in quadriceps. But results in simulation are really lower than I expected and I don't understand why that is happening.
I have put a force of 2kg in the foot with the function AnyForce3D:
AnyForce3D ForceFoot=
F = {0.0, -9.81, 0}*2;
AnyRefFrame &Ref_Foot2 = Main.HumanModel.BodyModel.Right.Leg.Seg.Foot;
AnyDrawForce Drw_Force1 = {
ForceScale=1;
To recreate the movement, firts I lock all the joints except right knee, with the function AnyKinEqSimpleDriver, and I have recreated knee flexion with the function AnyKinEqInterPolDriver:
AnyKinEqInterPolDriver KneeDriver =
CType = {Hard};
Type = Bspline ;
FileName = "Pos_knee.txt";
AnyKinMeasure& Ref_Knee = Main.HumanModel.BodyModel.Interface.Right.KneeFlexion;
And finally, I have added the reaccions between pelvin and ground using AnyReacForce:
AnyReacForce PelvisReactions =
AnyKinLinear lin =
AnyRefFrame& femur = ....BodyModel.Right.Leg.Seg.Thigh;
AnyRefFrame &ground = Main.Model.Environment.GlobalRef;
AnyKinRotational rot =
Type = RotAxesAngles;
AnyRefFrame& femur = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.PelvisSeg;
My problem is the joint moment in right knee, according the simulation the right knee have a moment between -0.55 and -0.50 Nm during exercises but when I have calculated this moment, my results are between -20 and 0 Nm and I don't know what is wrong.
I also attach the model at the post if someone could help me to find the problem.
Pau Zamora
HamstringExercises.zip (41.9 KB)
