joint moments of forces generated by the joints
For the gaitlowerextremity model I need to use moment of forces generated by the joints instead of the muscles. In the joints and drivers optimized file I set the Reaction.type to on. My question is where I can find the generated moments, because in the standard output the joint moments of forces are 0 now. And if it is not visible yet how can I generate this output?
Hans
Hi Hans,
Let’s assume that you are using ‘GaitLowerExtremity’ model and trying to perform the inverse dynamics analysis.
  1. Then you may use “BodyPartsSetup2.any” file which only includes joint muscles.
  2. In '“JointsAndDriversOptimized.any” file, let’s assume that you modify this file like this:
  #if LEFT_LEG_TD == 1
  AnyKinEqInterPolDriver JntDriverLeftLegTD = {
    FileErrorContinueOnOff = On;
    Type = Bspline;
    BsplineOrder = 4;
    FileName = Main.ModelSetup.C3DFileData.NameOfFile+"-output-euler-leftlegtd.txt";
    AnyKinMeasureOrg &HipFlexion = ...HumanModel.Interface.Left.HipFlexion;
    AnyKinMeasureOrg &HipAbduction = ...HumanModel.Interface.Left.HipAbduction;
    AnyKinMeasureOrg &HipExternalRotation = ...HumanModel.Interface.Left.HipExternalRotation;
    AnyKinMeasureOrg &KneeFlexion = ...HumanModel.Interface.Left.KneeFlexion;
    AnyKinMeasureOrg &AnklePlantarFlexion = ...HumanModel.Interface.Left.AnklePlantarFlexion;
    AnyKinMeasureOrg &SubTalarEversion = ...HumanModel.Interface.Left.SubTalarEversion;
    //Reaction.Type={Off,Off,Off,Off,Off,Off};
    Reaction.Type={Off,Off,Off,[b]On[/b],Off,Off};
  #endif
  #if RIGHT_LEG_TD == 1
  AnyKinEqInterPolDriver JntDriverRightLegTD =  {
    Type = Bspline;
    BsplineOrder = 4;
    FileName = Main.ModelSetup.C3DFileData.NameOfFile+"-output-euler-rightlegtd.txt";
    AnyKinMeasureOrg &HipFlexion = ...HumanModel.Interface.Right.HipFlexion;
    AnyKinMeasureOrg &HipAbduction = ...HumanModel.Interface.Right.HipAbduction;
    AnyKinMeasureOrg &HipExternalRotation = ...HumanModel.Interface.Right.HipExternalRotation;
    AnyKinMeasureOrg &KneeFlexion = ...HumanModel.Interface.Right.KneeFlexion;
    AnyKinMeasureOrg &AnklePlantarFlexion = ...HumanModel.Interface.Right.AnklePlantarFlexion;
    AnyKinMeasureOrg &SubTalarEversion = ...HumanModel.Interface.Right.SubTalarEversion;
  #endif
Then the joint muscles on knee joints will not work because the reaction of those joints are ‘on’.
Then, you can see the moments of this joints here:
Main.Studies.InverseDynamicStudy.ModelEnvironmentConnection.JointsAndDrivers.JntDriverLeftLegTD.Reaction.Fout[3]
Main.Studies.InverseDynamicStudy.ModelEnvironmentConnection.JointsAndDrivers.JntDriverRightLegTD.Reaction.Fout[3]
I hope that this can be an answer for you.
I adjusted the model and found the new moments of forces, but I have one important question left: Since I use other reference frames in the segments and joint nodes how can I generate the moments of forces with the adjusted reference frames?
Hans
Hi Hans,
I’d like to suggest you to use ‘AnyForceMomentMeasure2’ class.
You can see the detail description of this class in the reference manual.
Also, you can see the example of this class here:
‘\AMMRV1.4\Body\AAUHuman\LegTD\LegMoments.any’
That class I am already using but it will show the same results as in the standard output I constructed it as follows:
[SIZE=3]AnyForceMomentMeasure2[/SIZE] AnklePlantarFlexionNetMomentAnalyse = {
[SIZE=3]AnyRefNode[/SIZE] &ref=Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Shank.AnkleJointAnalyseRight;
[SIZE=3]AnyRefNode[/SIZE] &ref2=Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Talus.AnkleJointAnalyseRight;
[SIZE=3]
[/SIZE][SIZE=3]AnySeg[/SIZE] &seg1 =Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Foot;
[SIZE=3]
[/SIZE][SIZE=3]// #include “C:\bestanden\AMMRV1.4 - kopie\Body\AAUHuman\LegTD\LegMuscleNamesAnalyse.any”
[/SIZE]
[SIZE=3]// IncludeGravity=On;
[/SIZE][SIZE=3]AnyReacForce[/SIZE] &jnt1=Main.Studies.HumanModel.BodyModel.Right.Leg.Jnt.Ankle.Constraints.Reaction;
[SIZE=3]AnyReacForce[/SIZE] &jnt2=Main.Studies.HumanModel.BodyModel.Right.Leg.Jnt.SubTalar.Constraints.Reaction;
[SIZE=3][/SIZE][SIZE=3]
[/SIZE][SIZE=3]AnyVec3[/SIZE] Mlocal=M*ref.Axes;
[SIZE=3]
[/SIZE][SIZE=3]AnyVar[/SIZE] MPlantarFlexion=Mlocal[2];
Why does it still produce the same output even when it is a different defintion?
Hans
Hi Hans,
  1. First, I don’t know how you defined your ‘AnkleJointAnalyseRight’ node as the point of interest for AnyForceMomentMeasure2 class if you do not upload your model.
    So I’m sorry I can’t make the exact answer for you.
  2. Generally, the joint muscles(when using “BodyPartsSetup2.any” file in the inverse dynamics) are just torque generators for human joints.
    So even if we put ‘AnyReacForce’ on the joint drivers, the resultant torque should be same from the result of joint muscles.
I have a few important questions for you:
When using the forceplates the ankle joint forces are correctly calculated, but this is not the case for the moment of forces. How is that moment of force exactly calculated in the analysis?
How can I use the anyforcemoment2 class if there are no muscles available(since there are no useful moment data)?
Are the reaction forces calculated in a local reference frame or in the global reference framework?
If they are local is it possible to replace those reactions with my own output?
Is it possible to change the reactionforces?
Hans
Hi Hans,
I’m sorry for not understanding your intention of question very well early.
First, I would suggest you to use “BodyPartsSetup.any” file to include all muscles again when you are doing InverseDynamics.
Also set the reaction’s type as ‘off’ in the joint drivers to make sure that muscles will work(“JointsAndDriversOptimized.any”).
Then, in the ‘Main.Studies.HumanModel.BodyModel.Right.Leg.MomentMeasure’ folder,
you can see several moment measures.
(\AMMRV1.4\Body\AAUHuman\BodyModels\GenericBodyModel\RightLegTDSimpleMuscles.any)
  1. AnyForceMomentMeasure2 AnklePlantarFlexionNetMoment
    -> This will consider both all muscle forces and joint reactions related to Ankle joint
  2. AnyForceMomentMeasure2 AnklePlantarFlexionNetMomentMuscle
    -> This will consider only muscle forces related to Ankle joint
  3. AnyForceMomentMeasure AnkleJointReactionMoments
    -> This will consider only joint reactions related to Ankle joint
So as far as I understand, you may need the third measure.
And the output(M) of AnyForceMomentMeasure and AnyForceMomentMeasure2 are represented with respect to global coordinate system.
But in the third one(AnkleJointReactionMoments) you can also see ‘Mlocal’ value, which transforms M into local coordinate system of Ankle joint.
Then also you can see that Mlocal[2] value is always almost zero.
If you can compare these three measures, I hope that you can see what you want to do.
Actually I need to have the reaction moments as constructed in
Main.Studies.InverseDynamicStudy.ModelEnvironmentConnection.JointsAndDrivers.JntDriverRightLegTD.Reaction.Fout. But those reaction moments are constructed in the local reference framework so I made this transformation:
[SIZE=3][SIZE=3]AnyFloat [/SIZE]GlobalAnklePlantarFlectionMoment=[SIZE=3] [/SIZE]AnklePlantarFlexionReactionMomentLocal*Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Foot.Axes’;
Is this correct and how do I get the resultant of this transformation?
Hans
[/SIZE]
AnyReacForce value is represented with respect to the first reference frame of its corresponding kinematic measure.
  1. If we see ‘JointsAndDriversOptimized.any’ file,
    Type = Bspline;
    BsplineOrder = 4;
   [b] AnyKinMeasureOrg &AnklePlantarFlexion = ...HumanModel.Interface.Right.AnklePlantarFlexion;[/b]
  #endif
  1. Next, we should see “\AMMRV1.4\Body\AAUHuman\LegTD\Interface.any” file.
AnyKinMeasureOrg AnklePlantarFlexion={
  AnyFolder &Shank = ..Seg.Shank.AnkleJoint;
  Shank ={
    AnyRefNode RotNode={
      ARel={{0,....Sign*-1,0},{....Sign*1,0,0},{0,0,1}};
  AnyFolder &Talus = ..Seg.Talus.AnkleJoint;
  Talus ={
      ARel={{....Sign*1,0,0},{0,....Sign*1,0},{0,0,1}};
  AnyKinRotational Ankle = {
    Type=RotAxesAngles;
    AnyRefNode &ShankNode = ...Seg.Shank.AnkleJoint;
    AnyRefNode &FootNode  = ...Seg.Talus.AnkleJoint;
  }; // End of Ankle
  MeasureOrganizer={0};
So, you should use ’ Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Shank.AnkleJoint’ reference node to transfrom AnyReacForce value into global value.
So my answer is,
AnyFloat GlobalAnklePlantarFlectionMoment_Right=
AnklePlantarFlexionReactionMomentLocal_Right*
Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Shank.AnkleJoint.Axes’;
Thank you for your reply but I have one remaining question left: You obtain 9 values after this multiply and what do I have to do with those 9 values to obtain the global moment of force?
Hans
Now I’m finalizing the answer to your question.
There are no 9 values to see. There are only 3 values.
  1. If you want to see the global moment vectors in GaitFullBody model
    Main.Studies.HumanModel.BodyModel.Right.Leg.MomentMeasure.AnkleJointReactionMoments.M
    Main.Studies.HumanModel.BodyModel.Left.Leg.MomentMeasure.AnkleJointReactionMoments.M
  2. If you want to see the local moment vectors in GaitFullBody model
    Main.Studies.HumanModel.BodyModel.Right.Leg.MomentMeasure.AnkleJointReactionMoments.Mlocal
    Main.Studies.HumanModel.BodyModel.Left.Leg.MomentMeasure.AnkleJointReactionMoments.Mlocal
Thank you for your reply but this is not what I was asking I was talking about this:
AnyFloat GlobalReactionMomentAnkle =Main.Studies.HumanModel.BodyModel.Right.Leg.Jnt.Ankle.Constraints.Reaction.Fout[3]*Main.Studies.HumanModel.BodyModel.Right.Leg.Seg.Shank.AnkleJoint.Axes’;
And this gives 9 vectors and how can I obtain one global value out of these 9 vectors.
Hans
You can see just following values:
Ankle moments generated by joint reactions in ‘Global’:
Ankle moments generated by joint reactions in ‘Local’:
Each vector contains only 3 values, not 9 values.
I hope this may helpful to you.
I’m sorry but I can’t help you more about this same question again.
