Dear AnyBody supports:
I am building a finger model to fit the experimental data. In some
cases, the model does not converge. One of the possibilities is that
the passive joint resistance is considered in the model. The joint
resistance is like a torional spring, its magnitude is proportinal to
the angular displacement away from the neutral position. My question
is how to build the joint resistance in a joint?
For example, the joint (CMC) is defined as following. Can you show me
hot to add a passive joint moment with a magnitude proportinal to the
joint angular displacement?
Thanks, John Wu
AnyFolder Jnts = {
AnyUniversalJoint CMC =
{ Axis1 = y;
Axis2 = z;
AnyRefNode &GroundNode = …GlobalRef.Metacarpal_thumb;
AnyRefNode &ProximalNode = …Segs.Proximal_Phalanx.CMC_JT_Node;
AnyFolder Drivers = {
AnyKinEqInterPolDriver CMCMotion = {
AnyUniversalJoint &Jnts = Main.ThumbModel.Jnts.CMC;
FileName = “FPL_cmc.txt”;
Type = Bspline;
BsplineOrder = 4;
Reaction.Type = {Off,Off};
AnyFolder Measurements = {
AnyForceMomentMeasure CMC_M =
AnyForceBase &CMC_M = Main.Drivers.CMCMotion.Reaction;
AnyRefNode &CMC_ref = Main.ThumbModel.GlobalRef.Metacarpal_thumb;
