Does the local joint coordinate system change during simulation for ever joint? with respect to the global coodinate system? or is it only the joint angle?
How can I read a joint’s orientation or current location coordinate system?
When I read the ‘r’ variable which represents the joint angles, is the output wrt to the local frame or GCS?
Yes, the local coordinate System changes in respect to the Global CS. A Joint is defined by two Nodes, and the first named is the reference. You will see the loads in the CS of the first named Node and “r” is also in local.
I think the best way to understand the angles is to draw the CS. You can make the CS visible with a simple command in the two nodes:
AnyDrawRefFrame drw = {};
In the Hip you can make the CS visible by adding this command in the Seg.any and PelvisSeg.any:
AnyVec3 HipJointStandard= {0.0, 0.0, …Sign0.0};
AnyRefNode HipJoint = {
sRel = .Scale(.HipJointStandard);
ARel = RotMat(…Sign-30pi/180,y) * RotMat(-18pi/180,z);
AnyRefNode HipJointRightTD = {
//This rotaion is needed to fit the data with the pelvis bone
ARel=RotMat(-24*pi/180,z);
sRel = .Scale({0.035, -0.115, 0.088});
Thank you very much for your reply.
However, I need to output the actual orientation not see it visually.
Which variable exactly refers to the final orientation of the joint?
Thank you for your reply.
What I am trying to do is dump the final orientation of the local frame of every joint wrt the global one. For example, if the rotation matrix for a local frame of joint X wrt the global fram is [0,1,0;-1,0,0;0,0,1], thats what i need to dump or output.
If you use the AnyMechOutputFileForce you can dump a lot of information. Have a look at the example in the reference manual. When you output a segment, then there is a an ‘r’ as the offset (distance to 0) and ‘Axes’ as the transformation Matrix in the output file.
Yes this is what I was looking for. However, what is the difference between Axes and ARel?
In the manual it says: Relative rotational transformation matrix
I have been able to draw the Local reference frame of all the joints, however I get two frames for each joint, one at the proximal and one at the distal. My question is, the joint angle variable ‘Pos’, to which reference frame is it relative? Proximal or Distal?
My other question is, can we set an initial position for the GH joint? Can we control the initial posture of the trunk?
I’m not sure if I got everything correct, but I’ll try to answer:
First, if you look into the joint definition, there are two nodes defined for a joint, loads and the position are always referred to the first mentioned. I’m not sure what you mean proximal and distal in that meaning. You should have to ref frames for the GH joint, one for the hum and one for the glen/scap-part.
The initial position for the joints is set in the Manequin.any file.
Thats exactly what I was after.
However, you mentioned in the Mannequin file, is it joint positions or angles that are specified?
I have another question.
in Anybody, what is the rotation direction convention?
Right-hand rule or left hand rule?
is clockwise positive or negative?
