Hi!
I'm having trouble to model data that I have been receiving from a neural network. The data isn't very accurate and can sometimes have markers at strange positions during a measurement but it should hopefully be good enough to model.
When I'm trying to simulate a simple movement with my model, using RunAnalysis, I get this error message:
Constraint #373 is above tolerance 1e-06, error = 0.000001, segment constr. 'Main.HumanModel.BodyModel.Left.ShoulderArm.Seg.Humerus'.
Constraint #374 is above tolerance 1e-06, error = 0.000001, segment constr. 'Main.HumanModel.BodyModel.Left.ShoulderArm.Seg.Ulna'
Kinematic analysis failed in time step 75. Position analysis is not completed.
Does anyone know if I can change some value so that the constraint isn't above tolerance? Or what might the error be due to?
I'm using a lot of extra drivers to get the model to run, because I do not have enough data points.
Thank you!
