Hi everyone,
I add weight load on the shank. First, I add weight load in walk, this problem didn't occur. Then, I add weight load in squat.The problem occur:
Progressing to solve kinematic optimality conditions and hard constraints.
Failed to solve kinematic optimality conditions and hard constraints after 5 fallback attemps.
Constraint violations for study 'Main.Studies.ParameterIdentification.KinematicStudyForParameterIdentification' :
Constraint #111 is above tolerance 1e-05, error = 0.000148, constr. #3 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #112 is above tolerance 1e-05, error = 0.000082, constr. #4 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.Ankle.Constraints'.
Constraint #114 is above tolerance 1e-05, error = 0.000025, constr. #1 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #115 is above tolerance 1e-05, error = 0.000011, constr. #2 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #116 is above tolerance 1e-05, error = 0.000266, constr. #3 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #117 is above tolerance 1e-05, error = 0.000226, constr. #4 in 'Main.HumanModel.BodyModel.Left.Leg.Jnt.SubTalar.Constraints'.
Constraint #303 is above tolerance 1e-05, error = 0.000678, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Talus'.
Constraint #304 is above tolerance 1e-05, error = 0.000481, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Foot'.
Constraint #305 is above tolerance 1e-05, error = 0.000067, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Shank'.
Constraint #306 is above tolerance 1e-05, error = 0.000067, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Thigh'.
Constraint #307 is above tolerance 1e-05, error = 0.000068, segment constr. 'Main.HumanModel.BodyModel.Left.Leg.Seg.Patella'.
ERROR(OBJ.MCH.KIN3) : C:/U..s/a..n/D..s/A..x/A..e/T..s/A..p/KinematicStudyForParameterIdentification.any(11) : KinematicStudyForParameterIdentification.InitialConditions : Kinematic analysis failed in time step 0 : Position analysis is not completed
I adjusted the initial position, but this didn't work.I attached the zip file to make it easier for everyone to help me find the cause of the error. I really appreciate if anyone could help me.
Best regards.
Xuan Guo
Plug-in-gait_Simple2.zip (258.2 KB)
