Hi Soren,
thank you very much for the advice, I now have a completely determinate system
with the marker drivers. Script notation may well be the death of me!! I look
forward to developing the model.
many thanks
Peter
AnyBody Support <support@anybodytech.com> wrote: Hej Peter
I have done a few corrections in the model, and now it is driven in the x
direction by a marker.
The problem was in the jointanddrivers2.any file, the way the free marker
was selected
AnyRefFrame &ref2=Main.MarkerTopology.M5.Seg
is not correct it should be
AnyRefFrame &ref2=Main.MarkerTopology.M5.FreeMarker;
Before it was trying to drive the asis marker wrt. the pelvis segment which
will not work, so you have to point at the free floating marker.
I have updated the JointAndDrivers2.any file in your folder and I also
updated the MarkerMover.any file to include a guess on the initial marker
position.
Of peter.worsley
Sent: 18 February 2008 12:19
Subject: [AnyScript] Re: kinematic indeterminate systems
Hi Soren,
I have tried to change the markers one at a time, but with no success.
The model still fails to run set initial positions despite attempts
++. I think there is something fundamentally wrong with the model, and
i would like to solve the problem personally but i have not made any
progress for a while. i will post the file up on the forum, see if
anyone else has had similar problems. I will attach a word document
explaining what i have changed to the model and the recurrent
problems. The file is freeposture107.
many thanks
peter
— In anyscript@yahoogrou ps.com,
“AnyBody Support” wrote:
> Hi Peter
> I am a little unsure if your kin analysis did run some steps or it
gave this
> error in the first step?
> Anyway it is not a good sign if the kinematics can not solve the
constraints
> down to the default level, it is usually a sign of that something is
wrong
> in the model. You can decrease this accuracy if you like using the
variable
> KinematicTol in the study, but doing so may also lead to jumpy muscle
> activities because you will introduce some slack in all the
constraints.
> In the debug phase it can be a good idea some times to increase the
> tolerance since it might make model move and you can sometimes get
an idea
> on what is the problem.
> As I have understood the way you are driving the model you have now
joint
> drivers in all joints and you are using the markers for driving the
pelvis
> only. If this is the case I think it is a little strange that the
> constraints it can not fulfil is the hipdriver, if the leg is driven by
> joint drivers only, it should always be possible for it to control this
> joint.
> Another thing you could try is to apply the drivers one by one on the
> pelvis. So first you could add a marker driver that would drive it
forward
> and remove the equivalent constraint in the driver between pelvis
and global
> ref. Then drive the height and so on. In this way it should be
possible to
> always have a running model.
> I hope this helps you move on.
> Best regards
> Søren
> _____
> From: anyscript@yahoogrou ps.com
[mailto:anyscript@yahoogrou ps.com]
On Behalf
> Of peter.worsley
> Sent: 13 February 2008 18:39
> To: anyscript@yahoogrou ps.com
> Hi Soren,
> I took your advice and tried to run the C3D data through the
> freeposture model. I have been putting some marker drivers into the
> pelvis and i have now reached the point where there are no kinematic
> indeterminancies, and I feel the markers are driving in the right
> directions. But i’m still getting the following multiple complaints,
> here’s an example;
> Constraint no. 127 above error tolerance 0.000001, error = 0.000001. -
> constr. #1 in
> ‘Main.Model.ModelEnvironmentConnection.Drivers.HipDriverRight’
> Constraint no. 128 above error tolerance 0.000001, error = 0.000001. -
> constr. #2 in
> ERROR(OBJ.MCH.KIN3) : C:\Documents and
Settings\prw204\Desktop\PhD\Anybody\Repository.6.1\ARep\Aalborg\FreePosture1
> 07\FreePosture.Main.any(89)
> : ‘Study’ : Kinematic analysis failed in time step 0
> I have been through the marker set matching the markers to the nodes
> on the segments. They are as close as i can make them for the initial
> position. Do i have to achive an error less than 0.0000001?
> Or does this error mean something different?
> Your help is always greatly appreciated
> many thanks
> Peter
> > Hi Peter
> > If you think that the problem is related to the pelvis I suggest
> that you
> > insert joint drivers for the hip, knee and ankle joint and only
> keep the
> > pelvis drivers, if it still does not run and the pelvis has drivers
> for six
> > dof then the problem is related to driving the pelvis, and you have
> isolated
> > the problem.
> > If this does not work then in line with what Christian wrote i would
> suggest
> > the following step procedure:
> > 1: Take the freeposture model replace the bodymodel with the twolegs
> model
> > remove the unwanted drivers. This should give you a model where all
> joints
> > are driven.
> > 2: Scale the model so the size is fitting place markers on the right
> > location of the bones.
> > 3: By making changes to the mannequin.any file, position the model
> so that
> > it fit in the best possible way with the marker locations of the
> recorded
> > markers. This will give you a good initial position guess which is
> important
> > for marker driven model like this one. 3: Now remove some of the
drivers
> > from the pelvis and replace them gradually by marker drivers, for
> each step
> > you do make sure the kinematics are running all the way through.
> > The two leg gait model has the following dof’s: 6 rigidbody dof of
> pelvis, 3
> > hip, 1 knee, 2 ankle in total for both legs this gives 18, so you need
> > exactly 18 drivers, and they must be able to drive these dofs.
When you
> > select which dof to driver for a specific marker it is usually a
> good idea
> > to select a direction which is normal to the long axis of the bone the
> > marker is attached too. Here it is important to understand the
> concept of
> > the AnyKinLinear measure and the difference of using a Ref=0 or
Ref=-1,
> > please refer to the manual if needed. You will get the best solution
> is you
> > use Ref=0, because this makes the model independent of the
> orientation of
> > the subject. Sometimes I do a small stick figure sketch which
shows the
> > drivers as arrows pointing in the right directions according to the
> segment
> > coordinate system.
> > 4: continue to remove the joint drivers replacing them by the marker
> > drivers, one by one until they are all replaced.
> > Best regards
> > _____
> On Behalf
> > Of peter.worsley
> > Sent: 12 February 2008 13:21
> > Hi Christian,
> > I tried to take your advice and I put in AnyStdJoints to stop my DOF
> > driver error for kinematic analysis. But I am still getting a
> > indeterminant system. I have based my model on the Aalborg gait 3D,
> > but I notice that you have added a sacral marker set in the model (i
> > am using PSIS). I think the problem is lying in the pelvis, I have
> > contrained 160 out of 161 contraints and tried to make a sacral marker
> > but with no luck (its coming up with unsovlable constraint, when i
> > run the model).
> > Your help would be greatly appreciated as always
> > many thanks
> > Peter
ps.com,
> > > Hi Peter
> > > My experience is that using trial and error mostly creates
errors:D I
> > > think it is important that the model always runs, so start letting
> > > everything be “not driven” and then you add/remove a DOF once at a
> > > time. Depending on how you drive the model it is always good to be
> > > able to see the axis of the coordinate system in the reference frame
> > > you drive it in. It is always a good idea to write down in what DOF
> > > that you want to drive the different segments, in that way you can
> > > sort of plan your programming:D
> > > What model did you start from? the gait3d model?
> > > Hope you get it right:D else please post again.
> > > Best regards
> > > Christian, AnyBody Support
> ps.com,
> > “peter.worsley”
> > > wrote:
> > > > Hi everyone,
> > > > I’ve been collecting gait data for my project and trying to run
> > > > kinematic analysis. i have been setting up my joints and drivers
> > > > folder to constrain/drive the model. I am finding it hard to
> visualise
> > > > how to drive/constrain each degree of freedom. As a result i am
> using
> > > > trial and error in order to try and run the model. Is there any
> > > > function that allows me to check what plane a DOF needs to be
> > driven in?
> > > > many thanks
> > > > Peter
Users of the AnyBody Modeling System help each other create biomechanical models
in the AnyScript language.
Yahoo! Groups Links
Yahoo! Answers - Get better answers from someone who knows. Tryit now.
