Dear Soren,
I have looked through the bike model and i have come up with the main criteria i
needed to know and i am now concentrating on the Knee model i want to know some
information about the model and the forces acting on the knee?
Please if you can provide me with any information concerning the knee i will
appreciate it.
Thank you In Advance and with my Best Regards
Nesreen Aboulkhair
PhD Research Student.
Office 309b
Howell Building
School of Engineering and Design
Brunel Univesristy
Uxbridge
Middlesex
UB8 3PH
UK
Tel: +44 1895 267 200
Email: Nesreen.Aboulkhair@brunel.ac.uk <mailto:Nesreen.Aboulkhair@brunel.ac.uk?>
From: anyscript@yahoogroups.com on behalf of AnyBody Support
Sent: Mon 10/30/2006 12:52 PM
Subject: [anyscript] Re: Bike Model 3D
Hi Nina
If you look in the Tutorial “Getting started with AnyScript”
(Not “Getting started”) Lesson 2 there is a description on how the
masses and inertia is defined. You can also look at the
tutorial “The Mechanical Elements” Lesson 1.
There is also a tutorial which is based on a 2d bike model, so you
might be able to find some of the abbrevations there this is in
the “Parameter studies and Optimization” Lesson 1.
RPM means rounds per min.
Please ask again if you have further questions.
— In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> , “Nesreen
Aboulkhair”
<nesreen.aboulkhair@…> wrote:
> Thank you for replying. but i found some of the terms in the
script are not clear such as RPM? in the bike model so can you guide
a bit further please on where i should find the abbreviations
meanings. I have looked through the “Getting started” but i could
not find any thing to answer my question about the mass inertia.
> Thank you In Advance and appreciating your cooperation.
> Nina
> ________________________________
> From: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> on
> Sent: Mon 10/30/2006 11:46 AM
> To: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
> Hi Nina
> I think it will be a good idea to run some of the tutorials, you
can
> find them in the menu of AnyBody under “Help ->Contents”.
> The “Getting started with AnyScript” will answer some of your
> questions about mass, inertia etc.
> The driving torque is defined in the
file “BikeFramesAndWheel.any”,
> the object named “CrankMoment” defines the variation of the
> crankmoment as a function of the pedalangle.
> Best regards
<mailto:anyscript%
40yahoogroups.com> , “nina_rama2002”
> <nesreen.aboulkhair@> wrote:
> > Hi every one in anybody group,
> > I’m new to this group and i am facing some confusion in
> understanding
> > the Bike Mode. Actually i have successfully run it but i needed
to
> > understand more about the parameters used in this model the Mass
> > Inertia of the bone, Muscles, Length of it and the calculation
of
> > joint forces and the joint tork against the trank???
> > Driving tork.
> > Thanks
> > Nina
