Hallo,
I am trying to use the LegPressMachine example from AMMR V.1.6.2. and compare it with real data.
I have two problems,
a) where do I find the amount of force (weight) the "foot rest " applies and
b) when I try to change some values e.g. SubTalarEversion so I can have some alternations in my model, during the initialization, the model resets to it’s original position.
Is it possible to make such changes ? (reduce force, change angles etc)
There are three variables which can change the relative location of the foot with respect to the foot rest segment.
Also you can change the radius, thickness and the density of the barbell segment.
In the ‘TrailSpecificData.any’ file you can see the following section:
