Hi everyone
I hope to save the reults of kinematic data obtained from marker tracking analysis, so that i can perform inverse dynamic analysis directly next time without perform markertracking analysis again.
Thanks in advance!
Hi Felix,
This is exactly how the mocap models are set up in the AMMR. Marker tracking saves the kinematic data, which is then used in inverse dynamics analysis. You only need to run marker tracking one time, unless you make some changes that can affect the kinematics.
Thanks for your reply ![]()
