c3d files from VICON612 were converted using the “c3d2any”.
and I open the script “*.Main.any”.
but errors occur when i click the load model icon.
plz help…How can i run my mocap data by anybody?
Error message :
Loading Settings Script from : 'C:\Documents and Settings\HSH\Local
Settings\Application Data\AnyBody
Technology\AnyBody.3.x.x\Settings.anyst
ERROR(SCR.SCN1) : Cannot open file : C:\Documents and
Settings\HSH\Local Settings\Application Data\AnyBody
Settings file invalid and will be recreated. Using default settings.
Loading Main : “D:\MyDriver\AnyBody\DB\converted\CCSQ5_1
\CCSQ501.Main.any”
Scanning…
Parsing…
ERROR(SCR.PRS1) : D:\MyDriver\AnyBody\DB\converted\CCSQ5_1
\CCSQ501.Analog.any(19) : ‘FZ1’ : Object already declared at :
D:\MyDriver\AnyBody\DB\converted\CCSQ5_1\CCSQ501.Analog.any
(5) : ‘FZ1’
Model loading skipped
It looks like that you have defined analog data in your c3d file with the same
name. If you look in the .Analog.any file, you will that there are two places
with data called FZ1. If you rename one of them, your model should load.
Could you please verify that there really are two analog measurements in your
c3d file with the same name, so we can find the cause of the problem?
Thanks
Michael Skipper Andersen
The AnyBody Research Project
----- Original Message -----
Sent: Friday, October 05, 2007 8:15 AM
Subject: [AnyScript] load model error (converted c3d)
Error message :
\CCSQ501.Main.any”
Scanning…
Parsing…
(5) : ‘FZ1’
